I want to use the FMU AUX 5 as an encoder sensor on a Pixhawk C6, but I can’t read sensor data (using the rpm_capture driver) after arming it. My questions are:
- Is the mixer code located in the control allocator or in ~/src/lib/mixer_module?
- If I need to edit the mixer, what should I do to avoid damaging other configurations?
- Is there a template for editing the mixer, like the driver and module?
