How to control servo on AUX1 port of PX4(via code - not RC)
Hello All,
I am trying to operate(code based) a servo at AUX1 & AUX2 ports of my Hexrotor_x, I did try to setup mixer file for AUX ports in the microSD card ‘etc/mixers/epmg.aux.mix’
and tried publishing group_mix=3 , controls[6] & controls[7] direct PWM of 2000us, I see this publishing on mavros/actuator_control topic but when I check mavros/rc/out I still don’t see this 2000 output!!
Wondering what could be the issue?
Can You please guide me…
(I did check the process followed in How to control servo (via code - not RC)) but couldn’t achieve the result..
Enable pass through mixer on servo outputs 1-3
AUX1 channel (select RC channel with RC_MAP_AUX1 param)
M: 1
S: 3 5 10000 10000 0 -10000 10000
AUX2 channel (select RC channel with RC_MAP_AUX2 param)
M: 1
S: 3 6 10000 10000 0 -10000 10000
AUX3 channel (select RC channel with RC_MAP_AUX3 param)
M: 1
S: 3 7 10000 10000 0 -10000 10000
I have the same issue - im working on 1.13 - and trying to control aux servo via code - and cant find the way to do it, please help
Hey guys,
Can you update what you learn for doing this. I am gonna make for agriculturel drone and I need this control style.
