Hello Guys,
i think about to have two or more stages for battery fail-save.
- Battery half: return to land.
- Battery empty: land
is this possible and how it is possible?
Many thanks
Hello Guys,
Many thanks
Isn’t this already what is implemented, except that you need to adjust the limits?
@MaEtUgR can you confirm?
I see only one option in Safety.
Empty Battery
Can you explain me, how this works with two levels?
The battery simulation for SITL is here:
So you could adapt this simulation to go all the way down to 0 and play with it to find out what happens
i see there no info.
You are shure to understand my questiion?
I seach a parameter, which defined the action by half of battery.
Thanks for help
Ok, now i understand.
Critical - Failsave (return)
Emergency - Land
Low - Warning
Failsave means “return mode at critical low level” ?
Emergency means “reaching dangerously low levels” ?
So i have to increase the “Critical level” for return.
thanks
Yes, by default the thresholds are:
BAT_LOW_THR 15%, BAT_CRIT_THR 7%, BAT_EMERGEN_THR 5%
which results in:
15% - “OK”
COM_LOW_BAT_ACTYou can set these parameters on your vehicle to set different thresholds. As @JulianOes mentioned you can test the reactions in SITL simulation on your computer by setting the minimal simulated percentage (default is 50%) to the value 0.0f here: PX4-Autopilot/src/modules/simulator/simulator_mavlink.cpp at c50c44cc582956aefd32e39a6c7a5210ba4e1585 · PX4/PX4-Autopilot · GitHub
I strongly recommend to you to follow these instructions such that you get meaningful battery percentage values out of your power module setup and configuration: Redirecting to latest version of document (master)
