Hello everyone,
I’m trying to create new models based on existing ones in the /PX4-Autopilot/Tools/sitl_gazebo/models/
I started this by copying a directory, iris for example, and change all occurances of iris in that directory o iris2.
then I simply did
DONT_RUN=1 make px4_sitl_default gazebo
but when trying to run px4 in sitl using the following command:
make px4_sitl gazebo_iris2
or
make px4_sitl gazebo_iris2__baylands
I get :
ninja: error: unknown target 'gazebo_iris2', did you mean 'gazebo_iris'? │
make: *** [Makefile:230: px4_sitl] Error 1
A second question :
I noticed there are .sdf.jinja and sdf.last_generated in the model directories as well. however, when I removed them, now the model is not loaded saying model cant be found. are these not supposed to be generated on the fly during px4 build? if so why am I getting this error?
How am I supposed to force their regeneration?
Whats wrong here? any help in this is greatly appreciated
jinja files are generating sdf files which will be used by Gazebo. If you don’t want to edit jinja don’t delete and I suggest copy the sdf file you edited before next to the jinja file after make.
I can’t remember exactly but somehow ‘make’ system try to find jinja file but uses sdf file. So after ‘make’ change the sdf file with yours. It worked that way as remembered.
