Jacob Dahl 5:55 PM
Migrating issue from slack
I flashed
master… and now my motors are getting driven like Flashing back to 1.9.2 does not fix the issue…here’s the full chain of events.
- Flash
1.9.2, set s500_holybro airframe, fly around great.- Flash
master, reset params to default, reset airframe to s500_holybro .- Attempt to arm/fly, drone stays on ground (at max throttle) and motors are making a disturbing sound
- Fly two separate airframes with Pixhawk4 on
master… they fly great…- Reflash my S500 with
1.9.2and reset params/airframe again… attempt to arm/fly and same terrible motor behavior.Log from first great flight with 1.9.2 https://review.px4.io/plot_app?log=12fc1bfb-661e-4dd1-9794-5258427de23d
Log from attempting to fly withmaster, (I had someone hold it while I played with the sticks) https://review.px4.io/plot_app?log=8232b19b-8654-4646-b41e-91993091d092
Log from attempting to fly after flashing back to1.9.2https://review.px4.io/plot_app?log=0a4a98c2-2916-487b-9fa1-71215f66d2e8Something is amiss here and I can’t figure it out… whatever the differences are clearly they’re not being captured in the s500_holybro airframe config. It seems like the thing “flew great” after being shipped to m. My hunch is a full parameter reset wiped something out and I am not sure what…
Continued…
So I had @dagar help me with this, and I got it fixed. By fiddling with the PWM_RATE (set to something other than 400, power cycles, set back to 400, power cycle) I was able to get the ESCs functioning again. A theory is the ESCs are getting stuck in the wrong mode. I went ahead and reproduced this, it is as easy as flashing
mastervia the CLImake px4_fmu-v5_default. No amount of fiddling with the PWM_RATE settings restores proper functionality. I flashed back to1.9.2again … this time no fiddling with PWM_RATE was required, they justed worked as expected. Could the flashing of thepx4iobe screwing with the ESCs
