Hi PX4 community,
I’m facing an issue while running make px4_fmu-v3_default
in my PX4-Autopilot setup on Cygwin ( windows ). The build process stops with a CMake error indicating that the C++ compiler (arm-none-eabi-g++) cannot compile a simple test program. Here’s the relevant error message:
Dell@Harsh ~/PX4-Autopilot
$ make px4_fmu-v3_default VERBOSE=1
Re-run cmake no build system arguments
-- PX4_GIT_TAG: v1.15.0-beta1-2620-ge8f8bc9af7
CMake Warning (dev) at CMakeLists.txt:176 (find_package):
Policy CMP0148 is not set: The FindPythonInterp and FindPythonLibs modules
are removed. Run "cmake --help-policy CMP0148" for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.9.16", minimum required is "3")
-- PX4 config file: /cygdrive/c/PX4/home/PX4-Autopilot/boards/px4/fmu-v3/default.px4board
-- PLATFORM nuttx
-- TOOLCHAIN arm-none-eabi
-- ARCHITECTURE cortex-m4
-- ROMFSROOT px4fmu_common
-- IO px4_io-v2_default
-- CONSTRAINED_MEMORY y
-- SERIAL_GPS1 /dev/ttyS3
-- SERIAL_TEL1 /dev/ttyS1
-- SERIAL_TEL2 /dev/ttyS2
-- SERIAL_TEL4 /dev/ttyS6
-- ROOT_PATH /fs/microsd
-- PARAM_FILE /fs/mtd_params
-- UAVCAN_INTERFACES 2
-- PX4 config: px4_fmu-v3_default
-- PX4 platform: nuttx
-- The CXX compiler identification is GNU 9.3.1
-- The C compiler identification is GNU 9.3.1
-- The ASM compiler identification is GNU
-- Found assembler: /cygdrive/c/Program Files (x86)/GNU Arm Embedded Toolchain/9 2020-q2-update/bin/arm-none-eabi-gcc.exe
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Check for working CXX compiler: /cygdrive/c/Program Files (x86)/GNU Arm Embedded Toolchain/9 2020-q2-update/bin/arm-none-eabi-g++.exe
-- Check for working CXX compiler: /cygdrive/c/Program Files (x86)/GNU Arm Embedded Toolchain/9 2020-q2-update/bin/arm-none-eabi-g++.exe - broken
CMake Error at /usr/share/cmake-3.28.3/Modules/CMakeTestCXXCompiler.cmake:60 (message):
The C++ compiler
"/cygdrive/c/Program Files (x86)/GNU Arm Embedded Toolchain/9 2020-q2-update/bin/arm-none-eabi-g++.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: '/cygdrive/c/PX4/home/PX4-Autopilot/build/px4_fmu-v3_default/CMakeFiles/CMakeScratch/TryCompile-sRqtpb'
Run Build Command(s): /usr/bin/ninja.exe -v cmTC_88049
[1/2] "/cygdrive/c/Program Files (x86)/GNU Arm Embedded Toolchain/9 2020-q2-update/bin/arm-none-eabi-g++.exe" -o CMakeFiles/cmTC_88049.dir/testCXXCompiler.cxx.obj -c /cygdrive/c/PX4/home/PX4-Autopilot/build/px4_fmu-v3_default/CMakeFiles/CMakeScratch/TryCompile-sRqtpb/testCXXCompiler.cxx
FAILED: CMakeFiles/cmTC_88049.dir/testCXXCompiler.cxx.obj
arm-none-eabi-g++.exe: error: /cygdrive/c/PX4/home/PX4-Autopilot/build/px4_fmu-v3_default/CMakeFiles/CMakeScratch/TryCompile-sRqtpb/testCXXCompiler.cxx: No such file or directory
arm-none-eabi-g++.exe: fatal error: no input files
compilation terminated.
CMake will not be able to correctly generate this project.
CMakeLists.txt:230 (project)
Error: /cygdrive/c/PX4/home/PX4-Autopilot/build/px4_fmu-v3_default is not a directory
make: *** [Makefile:227: px4_fmu-v3_default] Error 1
$ which arm-none-eabi-gcc
I’ve confirmed that the toolchain path and permissions are correctly set, but the compilation still fails. Any guidance to help resolve this issue would be much appreciated!
