Help Interpreting EKF2 Barometer & Wind Estimation Logs for Multicopter
Hi all,
I’m currently tuning the EKF2 settings on my multicopter and would appreciate some guidance understanding specific parts of the workflow and interpreting the log results.
Setup Overview:
  • Multicopter
  • Height reference set to GPS
  • Barometer is enabled for height fusion (EKF2_BARO_CTRL)
  • I aim to tune:
    • Static pressure position error correction
    • Wind estimation using drag specific forces
I have already completed a flight in Position mode, performing repeated maneuvers (forward/backward/left/right/up/down) from rest to full speed, in calm conditions as recommended.
Now I need help with:
  1. How to correctly interpret the outputs from:
    • baro_static_pressure_compensation_tuning.py
    • mc_wind_estimator_tuning.py
  2. How to check the validity of outputs to these EKF2 parameters:
    • EKF2_PCOEF_XP, XN, YP, YN, Z (for static pressure error correction)
    • EKF2_BCOEF_X, Y, EKF2_MCOEF, and EKF2_DRAG_NOISE (for wind estimation)
  3. Understanding the implications of these parameters on height estimation and stability during dynamic flight
Also, a quick clarification: Since my height source is GPS, is the baro still used actively for bias correction, or does it only serve as a fallback? I’ve extracted the .ulg file using QGroundControl and can share the log file if needed.
Thanks in advance for your support!
