Hello, when I try running a gimbal command in my DronecodeSDK C++ program, I get an error as follows:
[xx:xx:xx|Warn ] sending again, retries to do: 3 (205). (mavlink_commands.cpp:242)
This was tested in both SITL, and with the gimbal connected to PIxhawk, with both approaches throwing up the same warning. The gimbal itself is working fine when operated using an RC.
I am trying to find a solution for this. Any help on the matter would be greatly appreciated, thank you in advance!
