Hi Pixhawk/PX4 community,
I am trying to get started with the first application (Hello Sky) on Pixhawk 4 from the PX4 docs. Developing on a windows PC, I wrote an compiled the application using the Cygwin toolchain, and successfully uploaded it to the Pixhawk.
However, I can’t get a shell to open to communicate with the Pixhawk. When I try to pip-install pymavlink
and pyserial
The following error occurs upon the installation of the lxml
package
Error: Please make sure the libxml2 and libxslt development packages are installed.
This is an issue that apparently more people have when installing lxml
on Windows. I have tried the following solutions:
1. install lxml
with prebuilt binary
The most heard solution for Windows on stackexchange is to dowload a prebuilt binary wheel and install this with pip.
When I try this for the python 3.6 version (cp36, 64bit) or any of the other wheels, it gives the error
$ pip3 install lxml-4.5.2-cp36-cp36m-win_amd64.whl
ERROR: lxml-4.5.2-cp36-cp36m-win_amd64.whl is not a supported wheel on this platform.
None of the wheels in the list seem to work, maybe because of the Cygwin environment?
2. copy the libxml2
and libxslt
files over to the toolchain/cywin64/bin
folder
As per these instructions, you can just dowload the libxml2 and libxslt packages from here and place the files from the bin
folder in toolchain/cywin64/bin
As the original author writes, the libxml2
and libxslt
packages depend on zlib
and iconv
, so I also copied the contents of those packages over.
When testing their installation using xmllint --version
it does return something:
$ xmllint --version
xmllint: using libxml version 20909
compiled with: Threads Tree Output Push Reader Patterns Writer SAXv1 FTP HTTP DTDValid HTML Legacy C14N Catalog XPath XPointer XInclude Iconv ISO8859X Unicode Regexps Automata Expr Schemas Schematron Modules Debug Zlib Lzma
but for xsltproc --version
, the following error appears:
$ xsltproc --version
C:/PX4/toolchain/cygwin64/bin/xsltproc.exe: error while loading shared libraries: libxml2-2.dll: cannot open shared object file: No such file or directory
This I find very strange because the file is actually there in toolchain/cywin64/bin
. Maybe I should place the files in another location?
3. run the shell outside of Cygwin
Interestingly, I can install lxml
on my local install of Python. This made me question whether I could not just open the shell outside of the Cygwin console. I therefore made a local venv, pip installed pymavlink
and pyserial
and tried to run Tools/mavlink_shell.py
from there.
However, this script relies on the termios
package, which is only available for Unix.
By now I am out of options what to do to make the shell connection work. I hope that someone here knows how to solve this issue. Probably other developers using the Cygwin toolchain must have come across the same problems.
Thanks a lot for your help/thoughts!
