FW/VTOL Call: November 22, 2022
November 22, 2022
Tracked issues from last meeting
FW runway landing / takeoff revisions
  • in review @dagar
  • control allocation for fixed-wing issues: @ryanjAA will document and make issue
Failure detector - roll/pitch
  • @chris1seto will check circuit breaker and we look next meeting
Acro mode
  • go with the integral reset
  • could also disable proportional gain
  • @chris1seto will test all combos and report back
New issues
Quad-tailsitter SITL model flies poorly
  • CG behind CP makes it stable.. but this is wrong
  • @sfuhrer
Unifying rate controller
Updates
Fixed-wing hand-launch audit
  • @sfuhrer did some testing and clean up!
  • check that launch and runway don’t interfere @tstastny
  • need to check what happens with commanded takeoff. maybe clean up @tstastny @sfuhrer
  • let’s skip to next mission item if clicking takeoff waypoint after already in air (takeoff waypoint is NOT a position setpoint)
I’m not sure where the very original issue was reported, but regardless of CBRK_FLIGHTTERM, the board doesn’t disarm when inverted in manual mode.
I think we should purge this item on the agenda unless someone brings out a working issue reproduction guide.
