I am trying to write tests for a new module. I have been able to successfully write and run unit tests, but the functional tests do not compile. During linking, I get this error:
/home/jonathan/Testing/px4-autopilot/platforms/posix/src/px4/common/px4_daemon/pxh.cpp:119: error: undefined reference to 'list_builtins(std::map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, int (*)(int, char**), std::less<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, int (*)(int, char**)> > >&)'
collect2: error: ld returned 1 exit status
make[4]: *** [src/modules/test/CMakeFiles/functional-test.dir/build.make:118: functional-test] Error 1
make[3]: *** [CMakeFiles/Makefile2:15413: src/modules/test/CMakeFiles/functional-test.dir/all] Error 2
make[3]: *** Waiting for unfinished jobs....
This error still occurs even when all of the code does pretty much nothing. Here is a minimal reproducible example.
modules/test/test.h
namespace my_tests {
class MyClass {
public:
void MyFunction();
int param;
modules/test/test.cpp
#include "test.h"
MyClass::MyFunction() { param = 10; }
testTest.cpp
#include <gtest/gtest.h>
#include <test/test.h>
using namespace my_tests;
class MyClassTest : public ::testing::Test, public MyClass {
public:
TEST_F(MyClassTest, FirstTest) {
ASSERT_EQ(0,0);
CMakeLists.txt
px4_add_library(TestLib test.cpp)
px4_add_functional_gtest(SRC testTest.cpp LIBS TestLib)
The other functional tests that come with the code work fine, but I can’t find the difference between my code and that code.
