I am trying to write unit/functional tests for a custom module, but following the directions on the developer guide leads to linking failures during the build. To verify that it is not my code that is causing the issue, I added a barebones functional test to the logger module.
#include <logger/logger.h>
#include <gtest/gtest.h>
class loggerTest : public ::testing::Test
public:
void SetUp() override
return;
TEST_F(loggerTest, testSomeFunction)
EXPECT_EQ(0, 0);
Adding the corresponding gtest statement to the CMakeLists.txt file:
px4_add_module(
MODULE modules__logger
MAIN logger
PRIORITY "SCHED_PRIORITY_MAX-30"
COMPILE_FLAGS
-Wno-cast-align # TODO: fix and enable
SRCS
logger.cpp
log_writer.cpp
log_writer_file.cpp
log_writer_mavlink.cpp
util.cpp
watchdog.cpp
DEPENDS
version
px4_add_functional_gtest(SRC loggerTest.cpp LINKLIBS modules__logger)
Then building with make tests results in the following errors:
[ 93%] Building CXX object src/modules/logger/CMakeFiles/functional-logger.dir/loggerTest.cpp.o
In file included from /home/jonathan/Code/pixhawk/src/modules/logger/logger.h:42,
from /home/jonathan/Code/pixhawk/src/modules/logger/loggerTest.cpp:36:
/home/jonathan/Code/pixhawk/src/lib/version/version.h: In function ‘const char* px4_board_name()’:
/home/jonathan/Code/pixhawk/src/lib/version/version.h:56:9: error: ‘PX4_BOARD_NAME’ was not declared in this scope
56 | return PX4_BOARD_NAME;
In file included from /home/jonathan/Code/pixhawk/src/platforms/px4_defines.h:42,
from /home/jonathan/Code/pixhawk/src/modules/logger/log_writer_file.h:36,
from /home/jonathan/Code/pixhawk/src/modules/logger/log_writer.h:36,
from /home/jonathan/Code/pixhawk/src/modules/logger/logger.h:36,
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h: In static member function ‘static int ModuleBase<T>::run_trampoline(int, char**)’:
/home/jonathan/Code/pixhawk/src/platforms/px4_log.h:232:29: error: ‘MODULE_NAME’ was not declared in this scope
232 | px4_log_modulename(level, MODULE_NAME, fmt, ##__VA_ARGS__); \
/home/jonathan/Code/pixhawk/src/platforms/px4_log.h:428:27: note: in expansion of macro ‘__px4_log_modulename’
428 | #define PX4_ERR(FMT, ...) __px4_log_modulename(_PX4_LOG_LEVEL_ERROR, FMT, ##__VA_ARGS__)
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:185:4: note: in expansion of macro ‘PX4_ERR’
185 | PX4_ERR("failed to instantiate object");
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h: In static member function ‘static int ModuleBase<T>::start_command_base(int, char**)’:
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:208:4: note: in expansion of macro ‘PX4_ERR’
208 | PX4_ERR("Task already running");
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:214:5: note: in expansion of macro ‘PX4_ERR’
214 | PX4_ERR("Task start failed (%i)", ret);
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h: In static member function ‘static int ModuleBase<T>::status_command()’:
/home/jonathan/Code/pixhawk/src/platforms/px4_log.h:388:29: note: in expansion of macro ‘__px4_log_modulename’
388 | #define PX4_INFO(FMT, ...) __px4_log_modulename(_PX4_LOG_LEVEL_INFO, FMT, ##__VA_ARGS__)
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:287:4: note: in expansion of macro ‘PX4_INFO’
287 | PX4_INFO("not running");
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h: In member function ‘virtual int ModuleBase<T>::print_status()’:
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:301:3: note: in expansion of macro ‘PX4_INFO’
301 | PX4_INFO("running");
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h: In static member function ‘static int ModuleBase<T>::wait_until_running()’:
/home/jonathan/Code/pixhawk/src/platforms/px4_module.h:376:4: note: in expansion of macro ‘PX4_ERR’
376 | PX4_ERR("Timed out while waiting for thread to start");
Any advice on how to fix this issue? This is likely the same issue that was referenced here, but that got no responses.
