FTDI USB adapters from Pixhawk to Companion Computer
Hi !!
i have this FTDI
But i dont find any document , how to connect the cable FTDI to from Pixhawk to Companion Computer . At least , i want is the image that show the pin to connect .
Thanks !!
This is probably as close as you will come:
If you are not sure, try to:
  • check where is 5V or 3v3 (probably red and black)
  • Bridge (connect) TX and RX together. Connect it to the computer and in terminal check, if you can see your own echo.
see the connection standard:
