Hi guys, I am currently trying to build the communication between a Pixhawk 4 mini and an Up Core companion computer using a FDTI following this guide: https://docs.px4.io/master/en/companion_computer/pixhawk_companion.html.
The computer setup is done with ROS2 and already passed sanity check. Since there is no telem 2 port for Pixhawk mini, we use QGroundControl to change necessary parameter for telem 1 port:
[MAV_1_CONFIG] = TELEM 1
[MAV_1_MODE] = Onboard
[MAV_1_RATE] = 80000 Bytes/s
[MAV_1_FORWARD] = True
[SER_TEL1_BAUD] = 921600 baud.
For the FDTI, we connect it with RX/TX/CTS/RTX/GND following the guide.
However, when I try to see usb connected, I still can’t see Pixhawk on the usb list. I try to download a FDTI driver but I am lost in those APIs.
Should I actually launch something to able to detect the FC? What should I do now?
