Hi everyone!
I am setting up a rig in a lab for doing static thrust measurements. the sytem is all setup and working well but almost every time I get the PX4 refusing to arm because of AHRS, horizonal speed, and some other issues. The system is not intended for flight but the pixhawk is used to monitor other data so I do not want to remove it from the loop. I would like to know what parameters should I set to either not need to arm the system, or (ideally) allow me to arm the aircraft with tx command without any checks being done.
Let me know if you need more information.
Thanks,
Khris
