I am running PX4 v1.14. am using the uXRCE-DDS client to talk to the flight controller using ROS. However I see that the /fmu/out/battery_status topic is not available. When I look at the .yaml file for version 1.14 I see that it is not there. However I see that this topic is present on version 1.15 on its dds_topics.yaml file
Is there a way for me to recompile px4 v1.14 to include this topic? I was confused when reading this on: uXRCE-DDS (PX4-ROS 2/DDS Bridge) | PX4 User Guide (v1.14)
If you’re creating or modifying uORB messages you must manually update the messages in your workspace from your PX4 source tree. Generally this means that you would update dds_topics.yaml (opens new window), clone the interface package, and then manually synchronize it by copying the new/modified message definitions from PX4-Autopilot/msg (opens new window)to its
msgfolders. Assuming that PX4-Autopilot is in your home directory~, whilepx4_msgsis in~/px4_ros_com/src/, then the command might be:
rm ~/px4_ros_com/src/px4_msgs/msg/*.msg
cp ~/PX4-Autopilot/mgs/*.msg ~/px4_ros_com/src/px4_msgs/msg/
My questions are
- What is the interface package?
- If I am using a px4_msgs message battery_status (Which is included in version 1.14 of px4_msg, do I need to do manually update the messages in the workspace since all the other topics are using px4_msgs? This is really not a custom message I am creating, I just want my flight controller to say the topic.
