FMU <= MAVSDK => NavQ problems
Hi to everyone !!!
I want to make a communication between a i.MX 8M Mini SOM (NavQ) and a RDDRONE-FMUK66 flight controller. I installed all the packages, it was fine. When I test without serial cable I get this:
navq@imx8mmnavq:~/MAVSDK/examples/takeoff_land/build$ ./takeoff_and_land serial:///dev/ttymxc2:921600
[04:13:16|Info ] MAVSDK version: v0.29.0 (mavsdk_impl.cpp:27)
[04:13:16|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:404)
Waiting to discover system...
No system found, exiting.
When I use the serial cable I get this:
[04:15:24|Info ] MAVSDK version: v0.29.0 (mavsdk_impl.cpp:27)
[04:15:24|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:404)
[04:15:24|Debug] Component Autopilot (1) added. (system_impl.cpp:344)
[04:15:24|Warn ] RTT too high for timesync: 1.59862e+12 ms. (timesync.cpp:90)
[04:15:25|Warn ] sending again after 0.507136 s, retries to do: 3  (520). (mavlink_commands.cpp:239)
[04:15:25|Warn ] Command ack 200 not matching our current command: 520 (mavlink_commands.cpp:146)
[04:15:25|Warn ] RTT too high for timesync: 1.59862e+12 ms. (timesync.cpp:90)
[04:15:25|Warn ] sending again after 1.01066 s, retries to do: 2  (520). (mavlink_commands.cpp:239)
So, something is happening, something is working, but not as I expected.
All other parameters are like in the documentation:
MAV_1_CONFIG TELEM2 (the second one on the FMU)
MAV_1_FORWARD 0
MAV_1_MODE Onboard
MAV_1_RATE 0
on the FMU part the speed of the port is 921600
on the NavQ: $ stty -F /dev/ttymxc2 921600
Thank you very much!
Dobrea Dan.
I’ll have someone look at this.
Hang on…
i recomment to install mallink-router on the NavQ.
With this you can veryfy that the MavLink communication between FMU and NavQ is working.
Simply forward the stream via WiFi to a QGC Computer.
Instruction is on https://nxp.gitbook.io/8mmnavq/user-guide/mavlink-specific-details/installing-mavlink-router
After communication is verified add another local port to your mavlink-router config where MavSDK connects to via UDP.
Hi!
A short mention: when I made all the install & tests presented above I was on vacation. Due to limited space I had with me a FMU+power module+GPS module+a telemetry module and, also, a NavQ.
Now I am at home with all the equipment, cables & software and now when I connect to the HoverGames it is working perfectly:
[11:35:13|Info ] MAVSDK version: v0.29.0 (mavsdk_impl.cpp:27)
[11:35:13|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:404)
Waiting to discover system…
[11:35:13|Debug] Component Autopilot (1) added. (system_impl.cpp:344)
[11:35:13|Debug] Discovered 1 component(s) (UUID: 10832640680271026576) (system_impl.cpp:517)
Discovered system with UUID: 10832640680271026576
Discovered a component with type 1
Vehicle is getting ready to arm
or
$ ./calibrate serial:///dev/ttymxc2:921600
[11:37:40|Info ] MAVSDK version: v0.29.0 (mavsdk_impl.cpp:27)
[11:37:40|Debug] New: System ID: 1 Comp ID: 1 (mavsdk_impl.cpp:404)
[11:37:40|Debug] Component Autopilot (1) added. (system_impl.cpp:344)
[11:37:41|Debug] Discovered 1 component(s) (UUID: 10832640680271026576) (system_impl.cpp:517)
Calibrating accelerometer…
[11:37:41|Debug] MAVLink: info: [cal] calibration started: 2 accel (system_impl.cpp:250)
Progress: 0
In my opinion some arming preventing mechanism (mainly because I had an incomplete drone) it did not allow the operating system on the drone to launch/configure the internal modules correctly … and hence the problem.
Thank you very much for your help and excuse my inconvenience … but I have been struggling for over 4 days and from my point of view everything was OK … and it was OK ;-).
Best regards,
Dobrea Dan.
