I just tried to build 1.11.0 for px4_fmu-v5_default. It looks like the make system is unable to create the config.h from nuttx config:
Scanning dependencies of target nuttx_config_target
[ 3%] Generating nuttx/include/nuttx/config.h, nuttx/include/nuttx/version.h
make[4]: warning: jobserver unavailable: using -j1. Add ‘+’ to parent make rule.
make[4]: *** [tools/Makefile.unix:341: include/arch/board] Error 1
make[3]: *** [NuttX/CMakeFiles/nuttx_boards_build.dir/build.make:4360: NuttX/nuttx/include/nuttx/config.h] Error 2
make[3]: *** Deleting file ‘NuttX/nuttx/include/nuttx/config.h’
make[2]: *** [CMakeFiles/Makefile2:17540: NuttX/CMakeFiles/nuttx_boards_build.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs…
What might be causing this? I get easily lost when debugging the cmake system. With the same PC&setup e.g. 1.10.2 bulids fine.
Full build output:
$ make px4_fmu-v5_default
– PX4 version: v1.11.0
– PX4 config file: /home/jlaitine/TII/PX4/Firmware/boards/px4/fmu-v5/default.cmake
– PX4 config: px4_fmu-v5_default
– PX4 platform: nuttx
– cmake build type: MinSizeRel
– The CXX compiler identification is GNU 9.2.1
– The C compiler identification is GNU 9.2.1
– Found assembler: /home/jlaitine/bin/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
– Check for working CXX compiler: /home/jlaitine/bin/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-g++
– Check for working CXX compiler: /home/jlaitine/bin/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-g++ – works
– Check for working C compiler: /home/jlaitine/bin/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
– Check for working C compiler: /home/jlaitine/bin/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc – works
– Enabling double FP precision hardware instructions
– Found PythonInterp: /usr/bin/python3 (found suitable version “3.8.2”, minimum required is “3”)
– build type is MinSizeRel
– PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-399-gec93490
– Building and including px4_io-v2_default
– Found PythonInterp: /usr/bin/python3 (found version “3.8.2”)
– Using C++11
– Release build type: MinSizeRel
– ROMFS: px4fmu_common
– ROMFS: Adding rc.board_defaults
– ROMFS: Adding rc.board_sensors
– ROMFS: Adding rc.board_mavlink
– Found SVD:
– Configuring done
– Generating done
– Build files have been written to: /home/jlaitine/TII/PX4/Firmware/build/px4_fmu-v5_default
Scanning dependencies of target git_nuttx_apps
Scanning dependencies of target px4_config_file_target
Scanning dependencies of target uorb_headers
[ 0%] git submodule platforms/nuttx/NuttX/apps
[ 0%] Built target px4_config_file_target
[ 0%] git submodule platforms/nuttx/NuttX/nuttx
[ 0%] Generating uORB topic headers
Scanning dependencies of target git_ecl
[ 0%] git submodule src/lib/ecl
[ 0%] Built target git_nuttx_apps
Scanning dependencies of target mixer_gen
Scanning dependencies of target mixer_gen_6dof
[ 0%] Generating mixer_multirotor.generated.h
[ 1%] Generating mixer_multirotor_6dof.generated.h
[ 1%] Built target git_ecl
[ 1%] Generating mixer_multirotor_normalized.generated.h
[ 1%] Built target mixer_gen_6dof
Scanning dependencies of target ver_gen
Scanning dependencies of target git_gps_devices
[ 1%] Generating git version header
[ 1%] git submodule src/drivers/gps/devices
Scanning dependencies of target px4_uavcan_dsdlc
[ 1%] PX4 UAVCAN dsdl compiler
[ 1%] Built target git_gps_devices
Scanning dependencies of target git_uavcan
[ 1%] git submodule src/drivers/uavcan/libuavcan
[ 1%] Built target git_uavcan
Scanning dependencies of target libuavcan_dsdlc
[ 1%] Running dsdl compiler
[ 1%] Built target px4_uavcan_dsdlc
Scanning dependencies of target git_mavlink_v2
[ 1%] git submodule mavlink/include/mavlink/v2.0
[ 1%] Built target git_mavlink_v2
Scanning dependencies of target airframes_xml
[ 1%] Creating airframes.xml
[ 1%] Built target libuavcan_dsdlc
Scanning dependencies of target parameters_xml
[ 1%] Generating serial_params.c
[ 1%] Built target airframes_xml
[ 1%] Generating parameters.xml
[ 1%] Built target ver_gen
Scanning dependencies of target px4io_firmware
[ 1%] Creating directories for ‘px4io_firmware’
[ 1%] No download step for ‘px4io_firmware’
[ 1%] No patch step for ‘px4io_firmware’
[ 1%] No update step for ‘px4io_firmware’
[ 1%] Performing configure step for ‘px4io_firmware’
– PX4 config file: /home/jlaitine/TII/PX4/Firmware/boards/px4/io-v2/default.cmake
– PX4 config: px4_io-v2_default
Scanning dependencies of target nuttx_copy_and_apps_target
[ 1%] Built target parameters_xml
[ 1%] Built target uorb_headers
[ 1%] Copying NuttX/nuttx to build/px4_fmu-v5_default/NuttX
[ 1%] Built target nuttx_copy_and_apps_target
Scanning dependencies of target nuttx_config_kconfig_target
– Configuring done
[ 1%] Generating nuttx_config_kconfig.stamp
[ 2%] Built target nuttx_config_kconfig_target
Scanning dependencies of target nuttx_copy_config_dir_target
[ 2%] Copying NuttX config nsh
[ 2%] Built target nuttx_copy_config_dir_target
[ 2%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
– Generating done
– Build files have been written to: /home/jlaitine/TII/PX4/Firmware/build/px4_fmu-v5_default/external/Build/px4io_firmware
[ 2%] Performing build step for ‘px4io_firmware’
[ 1%] Generating uORB topic headers
[ 1%] Built target git_nuttx
Scanning dependencies of target nuttx_builtin_list_target
[ 1%] Built target git_nuttx_apps
[ 1%] Built target nuttx_builtin_list_target
[ 1%] Generating mixer_multirotor.generated.h
[ 3%] Creating airframes.xml
[ 3%] Built target airframes_xml
[ 3%] Generating serial_params.c
[ 3%] Built target mixer_gen
[ 3%] Generating parameters.xml
[ 2%] Built target nuttx_config_target
[ 3%] Built target parameters_xml
Scanning dependencies of target nuttx_context
[ 3%] Built target uorb_headers
[ 3%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 5%] Built target nuttx_copy_and_apps_target
[ 2%] Copying NuttX/nuttx to build/px4_fmu-v5_default/NuttX
[ 2%] Generating nuttx_config_kconfig.stamp
[ 2%] Generating nuttx/include/nuttx/config.h, nuttx/include/nuttx/version.h
[ 2%] Built target nuttx_context
[ 5%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 6%] Generating nuttx_config_kconfig.stamp
[ 6%] Built target nuttx_config_kconfig_target
Scanning dependencies of target nuttx_boards_build
Scanning dependencies of target builtins_clean_target
Scanning dependencies of target nuttx_xx_build
[ 3%] Generating nuttx_config_kconfig.stamp
[ 3%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
[ 3%] Copying NuttX config nsh
[ 6%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 6%] Copying NuttX config nsh
[ 6%] Built target nuttx_copy_config_dir_target
make[4]: *** [tools/Makefile.unix:357: arch/arm/src/board] Error 1
cmp: include/nuttx/version.h.tmp: No such file or directory
mv: cannot stat ‘include/nuttx/version.h.tmp’: No such file or directory
make[4]: *** [tools/Makefile.unix:280: include/nuttx/version.h] Error 1
make[3]: *** [NuttX/CMakeFiles/nuttx_xx_build.dir/build.make:87: NuttX/nuttx/include/nuttx/config.h] Error 2
make[2]: *** [CMakeFiles/Makefile2:18117: NuttX/CMakeFiles/nuttx_xx_build.dir/all] Error 2
make[3]: *** [NuttX/CMakeFiles/builtins_clean_target.dir/build.make:72: NuttX/nuttx/include/nuttx/config.h] Error 2
make[2]: *** [CMakeFiles/Makefile2:17640: NuttX/CMakeFiles/builtins_clean_target.dir/all] Error 2
[ 8%] Generating nuttx_config_kconfig.stamp
[ 8%] Copying NuttX config nsh
[ 8%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
make[7]: warning: jobserver unavailable: using -j1. Add ‘+’ to parent make rule.
[ 8%] Built target nuttx_config_target
[ 8%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 10%] Copying NuttX config nsh
[ 10%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
[ 10%] Generating nuttx/include/nuttx/config.h, nuttx/include/nuttx/version.h
[ 10%] Built target nuttx_context
Scanning dependencies of target nuttx_drivers_build
Scanning dependencies of target nuttx_apps_build
[ 10%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 12%] Generating nuttx_config_kconfig.stamp
[ 12%] Copying NuttX/nuttx to build/px4_fmu-v5_default/external/Build/px4io_firmware/NuttX
[ 12%] Copying NuttX config nsh
[ 12%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
[ 13%] Generating nuttx_config_kconfig.stamp
[ 13%] Copying NuttX config nsh
[ 15%] Copying NuttX config nsh
[ 15%] Copying NuttX compressed config nsh and inflating (make olddefconfig)
[ 15%] Generating nuttx/include/nuttx/config.h, nuttx/include/nuttx/version.h
make[7]: *** [tools/Makefile.unix:357: arch/arm/src/board] Error 1
make[6]: *** [NuttX/CMakeFiles/nuttx_boards_build.dir/build.make:4360: NuttX/nuttx/include/nuttx/config.h] Error 2
make[6]: *** Deleting file ‘NuttX/nuttx/include/nuttx/config.h’
make[5]: *** [CMakeFiles/Makefile2:5848: NuttX/CMakeFiles/nuttx_boards_build.dir/all] Error 2
make[5]: *** Waiting for unfinished jobs…
make[6]: *** [NuttX/CMakeFiles/nuttx_apps_build.dir/build.make:72: NuttX/nuttx/include/nuttx/config.h] Error 2
make[5]: *** [CMakeFiles/Makefile2:5912: NuttX/CMakeFiles/nuttx_apps_build.dir/all] Error 2
make[6]: *** [NuttX/CMakeFiles/nuttx_xx_build.dir/build.make:87: NuttX/nuttx/include/nuttx/config.h] Error 2
make[5]: *** [CMakeFiles/Makefile2:6381: NuttX/CMakeFiles/nuttx_xx_build.dir/all] Error 2
make[6]: *** [NuttX/CMakeFiles/nuttx_drivers_build.dir/build.make:666: NuttX/nuttx/include/nuttx/config.h] Error 2
make[5]: *** [CMakeFiles/Makefile2:6004: NuttX/CMakeFiles/nuttx_drivers_build.dir/all] Error 2
make[4]: *** [Makefile:106: all] Error 2
make[3]: *** [src/drivers/px4io/CMakeFiles/px4io_firmware.dir/build.make:112: external/Stamp/px4io_firmware/px4io_firmware-build] Error 2
make[2]: *** [CMakeFiles/Makefile2:12325: src/drivers/px4io/CMakeFiles/px4io_firmware.dir/all] Error 2
make[1]: *** [Makefile:152: all] Error 2
make: *** [Makefile:219: px4_fmu-v5_default] Error 2
And this is the output from nuttx_context.log:
LN: include/arch/chip to arch/arm/include/stm32
Create .version
LN: arch/arm/src/board to /home/jlaitine/TII/PX4/Firmware/build/px4_fmu-v5_default/NuttX/nuttx///src
Create .version
No directory at /home/jlaitine/TII/PX4/Firmware/build/px4_fmu-v5_default/NuttX/nuttx///src
Create version.h
Create version.h
LN: include/arch/board to /home/jlaitine/TII/PX4/Firmware/build/px4_fmu-v5_default/NuttX/nuttx///include
Answering to myself; never found out what was the problem, but “rm -rf * && git reset --hard && git submodule update --recursive --init” just fixed it.
rroche
September 4, 2020, 2:06pm
5
Make sure you are cleaning your environment when switching from branches a simple make clean helps clear previous builds and dependencies, and always verify your submodules are updated when switching branches.
Yes, in this case “make clean” didn’t help, and “git status” didn’t show any diff. Go wonder, something was left floating around in ignored files probably.
rroche
September 8, 2020, 5:11pm
7
Did you try a clean build? still no luck?
