Hello, i want to find a easy solution to stop motors with external circuit in parallel ,my idea is just to link pwm signal with mosfet or transistor to the ground , I wonder if it might not destroy the pixhawk , in piaxhawk 1 hardware there is 220 ohms resistor in series with servo output , i can not find the pixhawak 4 detailed hardware ,it should be the same thing and it can work , I want your idea on the subject
Related topics
Topic | Replies | Views | Activity | |
Shut down one ESC signal output in flight | 0 | 332 | September 12, 2019 | |
Problem with connecting the motor to PM07 and Pixhawk 4 | 0 | 619 | March 8, 2021 | |
Failsafe option when Pixhawk fails | 1 | 770 | November 29, 2018 | |
How to stop motor spining when throttle is down | 3 | 1867 | November 15, 2016 | |
Use Main Out as an On/Off Switch with Transmitter | 0 | 266 | December 10, 2020 |
