Describe the bug
Both SITL simulator jMAVsim and Gazebo failed to run correctly on Ubuntu 18.04 with v1.9.0. For jMAVsim, the simulator just won’t start. The Gazebo will start, but cannot finish gps fusion and would complain about datalink when trying to run commander takeoff.
To Reproduce
Steps to reproduce the behavior:
- Install use the setup script ubuntu_sim.sh.
- Switch to v1.9.0.
- Run either
make px4_sitl jmavsimormake px4_sitl gazebo. - See error
Expected behavior
The simulator should run and commander takeoff and commander land should work correctly.
Log Files and Screenshots
Here’s the output of make px4_sitl jmavsim:
[0/1] cd /home/jedichen/src/Firmware...ng/src/Firmware/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/jedichen/src/Firmware/build/px4_sitl_default/bin/px4
debugger: none
program: jmavsim
model: none
src_path: /home/jedichen/src/Firmware
build_path: /home/jedichen/src/Firmware/build/px4_sitl_default
SITL COMMAND: "/home/jedichen/src/Firmware/build/px4_sitl_default/bin/px4" "/home/jedichen/src/Firmware"/ROMFS/px4fmu_common -s etc/init.d-posix/rcS -t "/home/jedichen/src/Firmware"/test_data
INFO [px4] Creating symlink /home/jedichen/src/Firmware/ROMFS/px4fmu_common -> /home/jedichen/src/Firmware/build/px4_sitl_default/tmp/rootfs/etc
0 WARNING: setRealtimeSched failed (not run as root?)
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [dataman] Unknown restart, data manager file './dataman' size is 11798680 bytes
INFO [simulator] Waiting for simulator to connect on TCP port 4560
Buildfile: /home/jedichen/src/Firmware/Tools/jMAVSim/build.xml
make_dirs:
compile:
create_run_jar:
copy_res:
BUILD SUCCESSFUL
Total time: 0 seconds
Options parsed, starting Sim.
Starting GUI...
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:61)
Caused by: java.awt.AWTError: Assistive Technology not found: org.GNOME.Accessibility.AtkWrapper
at java.awt.Toolkit.loadAssistiveTechnologies(Toolkit.java:807)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:886)
at java.awt.Window.getToolkit(Window.java:1358)
at java.awt.Window.init(Window.java:506)
at java.awt.Window.<init>(Window.java:537)
at java.awt.Frame.<init>(Frame.java:420)
at java.awt.Frame.<init>(Frame.java:385)
at javax.swing.JFrame.<init>(JFrame.java:189)
at me.drton.jmavsim.Visualizer3D.<init>(Visualizer3D.java:107)
at me.drton.jmavsim.Simulator.<init>(Simulator.java:176)
at me.drton.jmavsim.Simulator.main(Simulator.java:895)
... 5 more
Then with ctrl+C, it would return ERROR [px4] Startup script returned with return value: 2.
Here’s the output of make px4_sitl gazebo.
[2/6] Performing configure step for 'sitl_gazebo'
-- install-prefix: /usr/local
-- Using C++17 compiler
-- Boost version: 1.65.1
-- system
-- thread
-- filesystem
-- chrono
-- date_time
-- atomic
-- thread
-- system
-- filesystem
-- program_options
-- regex
-- iostreams
-- date_time
-- chrono
-- atomic
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found version "3.0.0")
-- Looking for OGRE...
-- Looking for OGRE_Paging...
-- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
-- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
-- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
-- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
-- Looking for OGRE_Volume...
-- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
-- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread;-lpthread (found suitable version "3.0.0", minimum required is "2.3.0")
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
-- Found libzmq , version 4.2.5
-- Checking for module 'uuid'
-- Found uuid, version 2.31.1
-- Checking for module 'tinyxml2'
-- Found tinyxml2, version 6.0.0
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- FreeImage.pc not found, we will search for FreeImage_INCLUDE_DIRS and FreeImage_LIBRARIES
-- Checking for module 'gts'
-- Found gts, version 0.7.6
-- Checking for module 'libswscale'
-- Found libswscale, version 4.8.100
-- Checking for module 'libavdevice >= 56.4.100'
-- Found libavdevice , version 57.10.100
-- Checking for module 'libavformat'
-- Found libavformat, version 57.83.100
-- Checking for module 'libavcodec'
-- Found libavcodec, version 57.107.100
-- Checking for module 'libavutil'
-- Found libavutil, version 55.78.100
-- Checking for module 'jsoncpp'
-- Found jsoncpp, version 1.7.4
-- Checking for module 'yaml-0.1'
-- Found yaml-0.1, version 0.1.7
-- Checking for module 'libzip'
-- Found libzip, version 1.1.2
-- catkin DISABLED
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread;-lpthread;-lpthread (found version "3.0.0")
Gazebo version: 9.9
-- Configuring done
-- Generating done
-- Build files have been written to: /home/jedichen/src/Firmware/build/px4_sitl_default/build_gazebo
[3/6] Performing build step for 'sitl_gazebo'
ninja: no work to do.
[5/6] cd /home/jedichen/src/Firmware...ng/src/Firmware/build/px4_sitl_default
SITL ARGS
debugger: none
program: gazebo
model: none
GAZEBO_PLUGIN_PATH :/home/jedichen/src/Firmware/build/px4_sitl_default/build_gazebo
GAZEBO_MODEL_PATH :/home/jedichen/src/Firmware/Tools/sitl_gazebo/models
LD_LIBRARY_PATH :/home/jedichen/src/Firmware/build/px4_sitl_default/build_gazebo
Gazebo multi-robot simulator, version 9.9.0
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.1.105
[Wrn] [gazebo_barometer_plugin.cpp:66] [gazebo_barometer_plugin] Using default home altitude of 488 m
[Dbg] [gazebo_mavlink_interface.cpp:135] <joint_name> not found for channel[0] no joint control will be performed for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:135] <joint_name> not found for channel[1] no joint control will be performed for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:135] <joint_name> not found for channel[2] no joint control will be performed for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:135] <joint_name> not found for channel[3] no joint control will be performed for this channel.
[Wrn] [gazebo_mavlink_interface.cpp:124] joint [zephyr_delta_wing::propeller_joint] not found for channel[4] no joint control for this channel.
[Wrn] [gazebo_mavlink_interface.cpp:124] joint [zephyr_delta_wing::flap_left_joint] not found for channel[5] no joint control for this channel.
[Wrn] [gazebo_mavlink_interface.cpp:124] joint [zephyr_delta_wing::flap_right_joint] not found for channel[6] no joint control for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:135] <joint_name> not found for channel[7] no joint control will be performed for this channel.
[Msg] Connecting to PX4 SITL using TCP
[Msg] Lockstep is enabled
[Msg] Speed factor set to: 1
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [simulator] Simulator connected on TCP port 4560.
[Msg] Using MAVLink protocol v2.0
[Wrn] [GuiIface.cc:122] inotify_add_watch("/home/jedichen/.config/fcitx/dbus") failed: "No space left on device"
[Wrn] [GuiIface.cc:122] inotify_add_watch("/home/jedichen/.config/fcitx/dbus/5caf31f0505b49469d72dda6a4579221-0") failed: "No space left on device"
[Wrn] [GuiIface.cc:122] inotify_add_watch("/home/jedichen/src/Firmware/Tools/sitl_gazebo/models") failed: "No space left on device"
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 14570 remote port 14550
INFO [logger] Opened full log file: ./log/2019-06-20/08_46_40.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
pxh> INFO [ecl/EKF] EKF aligned, (pressure height, IMU buf: 22, OBS buf: 14)
INFO [ecl/EKF] EKF GPS checks passed (WGS-84 origin set)
INFO [ecl/EKF] EKF commencing GPS fusion
pxh> commander takeoff
pxh> INFO [commander] Takeoff detected
WARN [commander] Failsafe enabled: no datalink
INFO [navigator] RTL HOME activated
INFO [navigator] RTL: climb to 499 m (10 m above home)
INFO [navigator] RTL: return at 499 m (10 m above home)
INFO [navigator] RTL: land at home
INFO [commander] Landing detected
INFO [logger] closed logfile, bytes written: 2831591
pxh> shutdown
Additional context
I’ve had some experience with px4 and I had no problem in running jMAVsim on Ubuntu 18.04 with some older version of px4. I have a friend who met the exact same problem as I did and I also found a post talking about this. Any help would be appreciated.
