I am trying to setup PX4 SITL with ROS2 Humble and XRCE-DDS Gazebo simulation on Ubuntu 22.04 by following all steps in PX4 User manual.
However, I cannot establish my agent/client connection. When I run the command “make px4_sitl gz_x500”, my simulation starts properly, but when I launch the XRCEAgent: “MicroXRCEAgent udp4 -p 8888”, it stops and the following error appears in my first terminal:
pxh> INFO [commander] Ready for takeoff!
WARN [health_and_arming_checks] Preflight: GPS Vertical Pos Drift too high
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/register_ext_component_request 0 0 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/unregister_ext_component 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/config_overrides_request 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/arming_check_reply 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/message_format_request 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/mode_completed 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/config_control_setpoints 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/manual_control_input 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/offboard_control_mode 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/onboard_computer_status 255 255 255
WARN [health_and_arming_checks] Preflight: GPS Horizontal Pos Drift too high
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/obstacle_distance 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/sensor_optical_flow 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/goto_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/telemetry_status 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/trajectory_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_attitude_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_mocap_odometry 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_rates_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/differential_drive_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_visual_odometry 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_command 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_command_mode_executor 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_trajectory_bezier 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_trajectory_waypoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_thrust_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/vehicle_torque_setpoint 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/actuator_motors 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/actuator_servos 255 255 255
ERROR [uxrce_dds_client] create entities failed: rt/fmu/in/aux_global_position 255 255 255
Do you have an idea where this could come from?
Thanks for your time.
