I am trying to understand how the ekf module works in PX4, and I ran into a confusing part.
In src/modules/ekf2/EKF2.cpp I tried to follow how the angular rate is published, and the unit of the variables seem to be controversial.
First here we define imu_sample_new.delta_ang as [rad/s], but if the if statement goes here it is integrating the gyro output over time and it will be set as [rad].
Furthermore, here we should get [rad/s] for rollspeed, therefore the imu.delta_ang variable’s unit should be [rad/s/s].
(I have taken all unit definitions from corresponding .msg files.)
I’m sure I am missing something trivial but can someone point out where I made the mistake?
Thanks in advance for any help.
