Dualsky servo ds9410 + kakute h7 v1.3
You connect servos where it says “8 motor outputs”. That’s the signal pins where PWM is generated. You also need to connect GND and 5v, although make sure to provide enough 5v for the servos. The existing power module for the Kakute likely doesn’t provide enough for that.
