Dualsky servo ds9410 + kakute h7 v1.3
Hello everyone. A question arose. I am assembling VTOL based on Skywalker X8 using the Kakute H7 v1.3 flight controller and DualSky DS9410 servos. On this controller, I can’t find where this servo should be connected, I have two of them. Can you please help with this issue. Thank you. I am applying the controller circuit.
You connect servos where it says “8 motor outputs”. That’s the signal pins where PWM is generated. You also need to connect GND and 5v, although make sure to provide enough 5v for the servos. The existing power module for the Kakute likely doesn’t provide enough for that.
