I am new to QGround Control and I have a task to disable the button “Parameter”, so that a user cannot change any parameter. Is there a way to do that? Thanks
Set visible to false in
SetupView.qml
SubMenuButton {
setupIndicator: false
exclusiveGroup: setupButtonGroup
visible: QGroundControl.multiVehicleManager.parameterReadyVehicleAvailable &&
!QGroundControl.multiVehicleManager.activeVehicle.usingHighLatencyLink &&
_corePlugin.showAdvancedUI
text: qsTr("Parameters")
In future, if you don’t know the code well, to find such a location do a full text search of “Parameters” in *.qml files. One of the results is the location posted above.
Not the easiest thing to find.
Thank you very much for your response.
Looking at the code of the file src/AutoPilotPlugins/APM/APMSafetyComponent.cc, I made this change below by removing the qml file and it worked. But as I new, I am afraid that by removing this, the QGroundControl maybe will not working properly now. Do you think is a bad way to remove the qml file?
