Deriving MCU Pin Assignments from PX4 Source?
I am attempting to map the MCU pins for the HolyBro Kakuteh7Mini by looking through the files in its board directory ( PX4-Autopilot/boards/holybro/kakuteh7mini at main · PX4/PX4-Autopilot · GitHub ). The specific files I’ve referenced so far are:
  1. …/kakuteh7mini/nuttx-config/include/board.h
  2. …/kakuteh7mini/src/board_config.h
  3. …/kakuteh7mini/src/timer_config.h
Below is a screenshot with a sampling of some of the entries I’ve found so far.
My issue is that I’ve only been able to come up with 54 different pin assignments. For reference, this flight controllers uses an STM32H743VIH6, which is a 100-pin, ball grid array package. I’m not necessarily expecting every single pin to be used/implemented, but I am definitely expecting more than 54, so I feel as though I may be missing something.
Has anyone else ever tried to to do something similar for other MCUs/Flight Controllers? I was originally expecting to find a file (or files) that had all of the MCU ports/pins assigned, but maybe I am operating off of a bad assumption? Is this the correct place to look for this kind of information?
Thanks in advance for the feedback!
Those files are indeed what you should check. A few more pins might be connected and assumed by default, such as USB and SWD.
I”m working on the same board with v1.3. I use STM32CubeMX to better visualize pinout and clocking configuration.
