I have added a custom parameter into mc_pos_control but it will not appear in q ground control or in parameters.xml in build. Is there something I have to do to build the parameters?
Thanks in advance
here is the parameter code:
MPC Boosted angle
controls the max forward angle during boosted flight.
*@unit deg
After I copy the generated parameters.xml to qgroundcontrol/src/FirmwarePlugin/PX4/PX4ParameterFactMetaData.xml, and recompile the QGC, then the parameter that I added appeared. Is there some steps that are unnessary.
