Custom multi vehicle build error(same topic name error)
Hello everyone,
I’m attempting to set up a simulation(Gazebo classic, ROS2 humble) for multiple vehicles(iris_depth_camera and rover_depth_camera)
During the code build process, I encountered the following error.
[ERROR] [1705243878.281362595] [gazebo_ros_node]: Found multiple nodes with same name: /camera_controller. This might be due to multiple plugins using the same name. Try changing one of the the plugin names or use a different ROS namespace. This error might also result from a custom plugin inheriting from another gazebo_ros plugin and the custom plugin trying to access the ROS node object hence creating multiple nodes with same name. To solve this try providing the optional node_name argument in gazebo_ros::Node::Get() function.
To solve this, I add new depth_camera model. I changed the model name to depth_camera1 and made corresponding changes in the sdf.jinja file by modifying <camera_name>camera</camera_name> to <camera_name>camera1</camera_name>.
Despite these change, the issue persists.
When running only iris_depth_camera (depth_camera), I can observe the following topics:
/camera/camera_info
/camera/depth/camera_info
/camera/depth/image_raw
/camera/depth/image_raw/compressed
/camera/depth/image_raw/compressedDepth
/camera/depth/image_raw/theora
/camera/image_raw
/camera/image_raw/compressed
/camera/image_raw/compressedDepth
/camera/image_raw/theora
/camera/points
/clock
/parameter_events
/performance_metrics
On the other hand, when running only rover_depth_camera (depth_camera1), the observed topics are:
/camera1/camera_info
/camera1/depth/camera_info
/camera1/depth/image_raw
/camera1/depth/image_raw/compressed
/camera1/depth/image_raw/compressedDepth
/camera1/depth/image_raw/theora
/camera1/image_raw
/camera1/image_raw/compressed
/camera1/image_raw/compressedDepth
/camera1/image_raw/theora
/camera1/point
/clock
/parameter_events
However, attempting to run both models (iris_depth_camera and rover_depth_camera) simultaneously results in failure.
please help, give me advice to solve these problem. Thank you
Hi @eogks465 did you manage to setup this simulation? It would be great to know since I am planning to do the same but new to PX4.
hello, @kalhansb .
To solve that problem, need to change plugin name.
But, I don’t think this is an efficient solution.
Hi @eogks465 sorry for the reply. Can you please tell me if you are using Tools/simulation/gazebo-classic/sitl_multiple_run.sh or any other method to spawn multiple vehicles?
Yes, I changed the sitl_multiple_run.sh code and resolved the issue by changing the plugin name in the SDF file.
