Creating a new airframe in 1.16
My QGroundControl (QGC) version is 5.0.8 on Ubuntu. I have designed a custom coaxial dual-propeller airframe with the following startup script:#!/bin/sh
@name MicoAir H743 Coaxial Vanes
@type Coaxial Vanes
@class Copter
@output Motor1: Upper Motor (MAIN1)
@output Motor2: Lower Motor (MAIN2)
@output Servo1: CenterVane (MAIN6)
@output Servo2: Right Vane (MAIN7)
@output Servo3: left Vane (MAIN8)
@maintainer sunxiaoyu
. ${R}/etc/init.d/rc.mc_defaults
param set-default SYS_AUTOSTART 4006
param set-default CA_AIRFRAME 16
param set-default MAV_TYPE 3
param set-default PWM_MAIN_FUNC2 101
param set-default PWM_MAIN_FUNC4 102
param set-default PWM_MAIN_FUNC6 201
param set-default PWM_MAIN_FUNC7 202
param set-default PWM_MAIN_FUNC8 203
param set-default PWM_MAIN_RATE 50
param set-default CA_SV_CS0_TRIM 0.0
param set-default CA_SV_CS1_TRIM 0.0
param set-default CA_SV_CS2_TRIM 0.0
I have added this airframe file to the CMakeLists.txt. Additionally, I modified the actuator effectiveness matrix and module.yaml to add my newly defined CA_AIRFRAME.
After compiling and flashing the firmware successfully:
  1. My custom airframe does not appear in the QGC airframe list;
  2. However, all verifications via NSH shell work correctly: the control_allocator status command outputs normally, and the parameters CA_AIRFRAME and SYS_AUTOSTART are set properly;
  3. In the QGC Actuators page, my servos are labeled as Unknown: 201, Unknown: 202, Unknown: 203.
Please help me solve this problem
Hi there!
I do not know how to fix teh QGC issue, but as long as the SYS_AUTOSTART param is set correctly, you should be good to go.
The servos are most likely Unknown, as you did not properly set the number of servos. The mc_defaults has 0 and you did not specify any more. (probably CA_SV_CS_COUNT )
