Controller parameters offboard example Gazebo-PX4-iris-Mavros
I am running the Offboard example with ROS and PX4 in Gazebo as described here: https://dev.px4.io/en/ros/mavros_offboard.html
(There is no Hardware involved in my setup)
I am on Ubuntu 16.04 with the PX4/Firmware on the master branch.
I am making the target for gazebo and px4 with the command:
make px4_sitl_default gazebo
which opens an instance of gazebo with an IRIS drone on which PX4 is running.
Then I connect mavros to the PX4 instance through the following command
roslaunch mavros px4.launch fcu_url:=udp://:14540@localhost:14557
And then I run the offboard example node described in the link above. Everything works fine.
The IRIS model is loaded from the folder:
$src_path/Firmware/Tools/sitl_gazebo/models/iris
The world chosen is the iris.world in the folder:
$src_path/Firmware/Tools/sitl_gazebo/worlds
I was trying to understand better the whole architecture and I was wondering in which part of the code the controller parameters of the IRIS are loaded.
For example, where do I find the gains of the PID controller of the IRIS?
Could you point me in the right direction?
Thanks.
I have an update, maybe I found where the parameters are set. It should be in one of the files in the folder
~/src/Firmware/ROMFS/px4fmu_common
I think it should be in one of the files regarding the iris which could be in the folder init.d or init.d-posix
The files could be
/home/schiano/src/Firmware/ROMFS/px4fmu_common/init.d/airframes/10016_3dr_iris
or any of these
in the folder
~/src/Firmware/ROMFS/px4fmu_common/init.d-posix
However, I still can’t understand where the link with between Gazebo, the airframes and mixer file is done in the launch files or the files launched by the launch files.
