i’m trying to get communication between my drone and python. I did the tutorial and can interface a simulated drone, but can’t connect to an actual drone connected via USB.
Hi, not sure how you run things, but WSL and network access generally don’t play well by default from my experience. I think the issue is that the linux system doesn’t see the server running on the windows side, you need to do some funky port-forwarding to pass connections between the 2 as the wsl is on a separate domain by default. Check this:
(now seems a bit easier than the last time I checked it…)
It might be also an option to pass the USB connection to the WSL and do it all in Linux:
