Can't connect to pixhawk4 from system console
I follow the https://dev.px4.io/en/debug/system_console.html
and want to connect to system console
Connect to the fmu debug port using usb2serial cable
and set putty like below, when power on pixhawk4 ,I can get some "!@#$!@#$!@#$@$@#$…"In the console
image%20(2)
image%20(1)
image%20(3)
I dont know it means what
Can anyone help me???
@elton-choi,do you have some advise?? Thanks s lot
Is ground connected? Are you sure you’re using the correct COM port? You can check that by disconnecting whatever cable you’re using and checking if the port disappears.
I find out the reason
I have made a stupid mistake—
I connect pixhawk4 using usb-rs232 cable
when change to usb-ttl cable
system console can works well
thanks
