Cannot find Fast RTPS files
Hi everyone,
I am working on a project where I would like to port the control part on a cloud and exchanging data via 4G.
Right now I’m trying to setup the network and RTPS seems to be the way to go. I will use a Raspberry pi to connect on the 4G network using a dongle.
I think RTPS is installed correctly, the path is ok but after building there is no client file in the build.
I installed Px4 3 weeks ago. Anyone knows about this issue ?
edit1:
Information about my path:
$ echo $PATH /home/florian/.sdkman/candidates/gradle/current/bin:/opt/ros/kinetic/bin:/home/florian/gcc-arm-none-eabi-7-2017-q4-major/bin:/home/florian/bin:/home/florian/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
$ which fastrtpsgen
/usr/local/bin/fastrtpsgen
edit2:
Trying to run the manual generation also doesnt work since the python files missing in the src/Tools directory but are only in the srs/msg/tools/ directory.
Moreover, I can’t find the set(GENERATE_RTPS_BRIDGE on) in my cmake/config/posix_sitl_default.cmake so i just added set(GENERATE_RTPS_BRIDGE off), not sure if it is correct ?
Greetings,
Florian
Problem solved.
The tutorial conserning RTPS is not up to date with the latest version of PX4.
I had to move files inside the folder srs/msg/tools/ to src/Tools and run manually the python client/agent generator. It looks like the auto generator is not working anymore.
edit: it is not a good idea, read next posts
I am having the same problem here…
I moved the files to src/Tools and then I ran the “generate_microRTPS_bridge.py” script.
After that, I moved to “~/src/Firmware/src/modules/micrortps_bridge/micrortps_agent/build” and ran the “cmake …” and “make” commands, but I got an error.
It returns:
error: ‘get_header_length’ was not declared in this scope
uint16_t header_length = get_header_length();
Do you know what’s missing?
Thank you so much,
elBarto
edit :slight_smile:
I fixed it! There’s an error in the code…
In order to build the agent, you have to change:
to
uint16_t header_length = transport_node->get_header_length();
in microRTPS_agent.cpp:174:38
Hi elBarto,
Excellent I had the same issue with the agent. Did you manage to run the client as well ?
Greetings,
Lyris
I found out that the rtps module can be included in the build process using the makefiles whose names end with “_rtps”.
If you make the px4fmu-v3_rtps, the module is correctly built and included in the elf target file ([ 95%] Built target modules__micrortps_bridge__micrortps_client).
Unfortunately, I have a first generation pixhawk (one of those with the flash size issue) and I can’t upload the v3 firmware on it. The v2 firmware instead doesn’t have a makefile that includes the rtps module, probably because it wouldn’t fit in the flash.
Finally, I tried to build the “posix_sitl_rtps” makefile, but I got this error:
/home/emanuele/Firmware_clone/Firmware/src/modules/micrortps_bridge/micrortps_client/microRTPS_transport.h:41:7: error: redefinition of ‘class Transport_node’
I am still trying to make it work… let’s keep in touch
Yes idealy I would like to test everything in simulation. Right now I can run the agent and listener but not the client. I believe they changed quite a bit the Transport_node class. I’ll dig into the code tomorrow and let you know if I can get any results.
lyris
It finally worked for me. Did you try on a fresh Px4 firmware ?
Using posix_sitl_rtps links correctly the client and generate automatically the agent in the build as described here https://dev.px4.io/en/middleware/micrortps.html
I believe you got some errors because you manually generated the client and agent, maybe it does not overwrite correctly when you start building.
lyris
thank you so much for guiding me through it.
I did a fresh start, deleted the old folder, made a new one, pulled the repository… and it finally worked.
I have been able to build client, agent and listener. But when I run the client from the jMavsim console, it fails because it can’t open the /dev/ttyUSB0 port (how can I blame it since a physical tty port doesn’t exist).
So I think I will wait for a real pixhawk to test it. I have already ordered a new mRo Pixhawk.
Have you been able to make it work within the SITL simulator? It would be great to test it before flying :slight_smile:
Thank you again,
E.
Change the settings, you can run UDP instead of UART.
try:
micrortps_client start -t UDP
then for the agent:
./micrortps_agent -t UDP
then just run the listener and have fun
lyris
Awesome! It works :+1:
Thank you so much! :relaxed:
