I’m trying to learn more about QGroundControl by compiling it and playing around. I’m able to build and run for linux, but when opening the form editor I get the errors with QtQuick imports:
import QtQuick.Window 2.2 — QML module not found
I’ve got this for several versions of QtCreator and Qt, now I use Qt Creator 4.11.1 and Qt libs 5.12.5, as recommended in the docs. The problem is that I can’t learn how the UI stuff works (signals etc)
I’ve found a rather disheartening remark about this issue:
“An import statement
is always annotated with “QML module not found” error message.”
“This bug is very old! But still present unfortunately. It seems to be occurred very chancy in any platform and then it will be present and make developers sad. I already have same problem from some month ago and it is still here after many updates. I have not any solution yet.”
https://bugreports.qt.io/browse/QTCREATORBUG-20973
Is this still the case?
Interesting. I haven’t seen for example an Android project with the form editor not usable. Could you please write what’s the motivation? Too much hassle with configuring it? No need for it? No real advantage? No kidding here, I’m impressed by the quality of QGroundControl, as an user I have no problems with this app.
