Hello All,
I pretty much is at a roadblock when attempting to build an android version of QGC using the Stable V4.1 branch as my source, and QT creators. I followed the guide here:
https://dev.qgroundcontrol.com/master/en/getting_started/index.html
According to the guide, it is mentioned to use QT 5.12.6, and Android NDK version 19.
However, when I set up my QT Creator Devices, I get an error in the Android settings if I only have Android NDK v19.2.5345600 installed from Android Studio v4.2.1. The only way I can manage to resolve this is to install Android NDK v21.3.6258147 as well, and QT v5.12.6 selects Android NDK v21.3.6258147 automatically, so I am not sure if I am missing any steps here.
According to the link below, it seems that Android NDK r20b or r21 is the one that issupported by QT 5.12.6:
https://doc.qt.io/qt-5/android-getting-started.html
Anyway, I tried to proceed with my QT Creator environment setup with Android NDK v21.3.6258147, and attempt to build a release version for Android QT 5.12.6 Clang armeabi-v7a.
At the end of the build, the compile output tab shows “Build Success” with a whole lot of error messages in the issues tab.
I have double checked the packages that I installed, and I could not quite figure out what I am missing as the versions of the software components seems to be aligned. IDE versions installed in my PC are as below:
- Microsoft Visual Studio Community 2019
- Microsoft Visual Studio Community 2017
- QT 5.12.6
- QT 5.15.1
- Android Studio v4.2.1
- Gradle v7.0.2
- JDK v8.0.2910.10
- QT v5.12.6 Installed Components
- Android ARM64-v8a
- Android ARMv7
- Android x86
- MSVC 2017 64-bit
- QT Charts
- QT 5.15.1 Installed Components:
- MSVC 2015 64-bit
- Android
- Sources
- QT Charts
The Android SDK Tools that is installed in my PC is as below:
- Android SDK Build Tools 31-rc5 v30.0.2 and v28.0.3
- Android NDK (side-by-side) v21.3.6258147
- Android SDK Command-line Tools (latest) v4.0
- CMake v3.8.11
- Android Auto API Simulators v1
- Android Emulator v30.6.5
- Android SDK Platform-Tools v31.0.2
- Google Play APK Expansion libraty v1
- Google Play Instant Development SDK v1.9.0
- Google Play Licensing Library v1
- Google Play Services v49
- Google USB Driver v13
- Google Web Driver v2
- Intel x86 Emulator Accelerator (HAXM installer) v7.6.5
- Layout Inspector image server for API 29-30 v6
- Layout Inspector image server for API S v2
The Android SDK platforms I have installed is as below:
- Android 11.0 (R)
- Android SDK Platform 30
- Sources for Android 30
- Google APIs Intel x86 Atom System Image
- Google APIs Intel x86 Atom_64 System Image
- Android 7.0 (Nougat)
- Google APIs
- Android SDK Platform 24
- Sources for Android 24
- ARM 64 v8a System Image
- ARM EABI v7a System Image
- Intel x86 Atom_64 System Image
Release Build Errors:
C:\Users\micha\AppData\Local\Android\Sdk\ndk\21.3.6528147/toolchains/llvm/prebuilt/windows-x86_64/bin\llvm-strip.exe: error: unknown argument ‘-strip-all’
– Skipping C:/Qt/5.12.6/android_armv7/plugins/position/libqtposition_serialnmea.so. It has unmet dependencies: lib/libQt5SerialPort.so.
Warning: QML import could not be resolved in any of the import paths: QGroundControl.Palette
Warning: QML import could not be resolved in any of the import paths: Custom.Widgets
Warning: QML import could not be resolved in any of the import paths: org.freedesktop.gstreamer.GLVideoItem
Warning: QML import could not be resolved in any of the import paths: QGroundControl.Airspace
Warning: QML import could not be resolved in any of the import paths: QGroundControl.Controllers
Warning: QML import could not be resolved in any of the import paths: QGroundControl.MultiVehicleManager
Warning: QML import could not be resolved in any of the import paths: QGroundControl.SettingsManager
Warning: QML import could not be resolved in any of the import paths: QGroundControl.ArduPilot
Warning: QML import could not be resolved in any of the import paths: QGroundControl.QGCPositionManager
Warning: QML import could not be resolved in any of the import paths: QGroundControl.ShapeFileHelper
Warning: QML import could not be resolved in any of the import paths: QGroundControl.Templates
Warning: QML import could not be resolved in any of the import paths: QtQuick.Controls.impl
Warning: QML import could not be resolved in any of the import paths: QGroundControl.ScreenToolsController
Warning: QML import could not be resolved in any of the import paths: QGroundControl.QGCMapEngineManager
Warning: QML import could not be resolved in any of the import paths: MAVLink
Warning: QML import could not be resolved in any of the import paths: QGroundControl.AutoPilotPlugin
Warning: QML import could not be resolved in any of the import paths: QtQuick.Controls.Fusion.impl
Warning: QML import could not be resolved in any of the import paths: QtQuick.Controls.Imagine.impl
Warning: QML import could not be resolved in any of the import paths: QtQuick.Controls.Material.impl
Warning: QML import could not be resolved in any of the import paths: QtQuick.Controls.Universal.impl
Warning: QML import could not be resolved in any of the import paths: QtQuick.Extras.Private.CppUtils
