When I tried to build the project on Windows, I met the error
C:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QGCTileCacheWorker.cpp:719: error: C2220: warning treated as error - no ‘object’ file generated
It‘s the first time I build it
And here’s all the output:
21:28:38: Running steps for project qgroundcontrol…
21:28:38: Starting: “E:\Qt\Tools\QtCreator\bin\jom.exe”
cl -c -FIstable_headers.h -Yustable_headers.h -Fpobj\QGroundControl_pch.pch -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:throwingNew -Zc:referenceBinding -Zc:_cplusplus -Zi -MDd -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 /W3 /wd4996 /wd4005 /wd4290 /wd4267 /WX -EHsc /Fdobj\QGroundControl.vc.pdb -DUNICODE -D_UNICODE -DWIN32 -D_ENABLE_EXTENDED_ALIGNED_STORAGE -DWIN64 -DQGC_GST_TAISYNC_DISABLED -DQGC_GST_MICROHARD_DISABLED -D__STDC_LIMIT_MACROS -DQGC_ENABLE_MAVLINK_INSPECTOR -DGIT_VERSION="“Development master:5ca19ecc3 2020-03-12 23:24:30 +0000"” -DEIGEN_MPL2_ONLY -D_TTY_NOWARN -DQGC_DISABLE_PAIRING -DQGC_USE_ARDUPILOTMEGA_MESSAGES -DNOMINMAX -DQGC_APPLICATION_NAME="“QGroundControl”" -DQGC_ORG_NAME="“QGroundControl.org”" -DQGC_ORG_DOMAIN="“org.qgroundcontrol”" -DUNITTEST_BUILD -DQT_LOCATION_LIB -DQT_POSITIONINGQUICK_LIB -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_CHARTS_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CONCURRENT_LIB -DQT_POSITIONING_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_TEXTTOSPEECH_LIB -DQT_SERIALPORT_LIB -DQT_TESTLIB_LIB -DQT_CORE_LIB -DQT_TESTCASE_BUILDDIR="“C:/Users/ppott/Documents/build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Debug”" -DQT_QML_DEBUG -IC:\Users\ppott\Documents\qgroundcontrol -I. -IE:\Qt\5.12.6\msvc2017_64\include -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation -IC:\Users\ppott\Documents\qgroundcontrol\libs\msinttypes -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0 -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0\ardupilotmega -IC:\Users\ppott\Documents\qgroundcontrol\libs\eigen -IC:\Users\ppott\Documents\qgroundcontrol\libs\shapelib -IC:\Users\ppott\Documents\qgroundcontrol\libs\sdl2\msvc\include -IC:/Users/ppott/Documents/qgroundcontrol/libs/OpenSSL/Windows/x64/include -IC:\Users\ppott\Documents\qgroundcontrol -Iinclude/ui -IC:\Users\ppott\Documents\qgroundcontrol\src -IC:\Users\ppott\Documents\qgroundcontrol\src\ADSB -IC:\Users\ppott\Documents\qgroundcontrol\src\api -IC:\Users\ppott\Documents\qgroundcontrol\src\AnalyzeView -IC:\Users\ppott\Documents\qgroundcontrol\src\Camera -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightDisplay -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap\Widgets -IC:\Users\ppott\Documents\qgroundcontrol\src\FollowMe -IC:\Users\ppott\Documents\qgroundcontrol\src\Geo -IC:\Users\ppott\Documents\qgroundcontrol\src\GPS -IC:\Users\ppott\Documents\qgroundcontrol\src\Joystick -IC:\Users\ppott\Documents\qgroundcontrol\src\PlanView -IC:\Users\ppott\Documents\qgroundcontrol\src\MissionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\PositionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\QmlControls -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QMLControl -IC:\Users\ppott\Documents\qgroundcontrol\src\Settings -IC:\Users\ppott\Documents\qgroundcontrol\src\Terrain -IC:\Users\ppott\Documents\qgroundcontrol\src\Vehicle -IC:\Users\ppott\Documents\qgroundcontrol\src\ViewWidgets -IC:\Users\ppott\Documents\qgroundcontrol\src\Audio -IC:\Users\ppott\Documents\qgroundcontrol\src\comm -Isrc/input -Isrc/lib/qmapcontrol -IC:\Users\ppott\Documents\qgroundcontrol\src\uas -IC:\Users\ppott\Documents\qgroundcontrol\src\ui -Isrc/ui/linechart -Isrc/ui/map -Isrc/ui/mapdisplay -Isrc/ui/mission -Isrc/ui/px4_configuration -IC:\Users\ppott\Documents\qgroundcontrol\src\ui\toolbar -Isrc/ui/uas -IC:\Users\ppott\Documents\qgroundcontrol\src\qgcunittest -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\Common -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\VehicleSetup -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem\FactControls -IC:\Users\ppott\Documents\qgroundcontrol\src\Airmap\dummy -IC:\Users\ppott\Documents\qgroundcontrol\src\VideoStreaming -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6\QtLocation -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuickWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtOpenGL -IE:\Qt\5.12.6\msvc2017_64\include\QtSvg -IE:\Qt\5.12.6\msvc2017_64\include\QtPrintSupport -IE:\Qt\5.12.6\msvc2017_64\include\QtCharts -IE:\Qt\5.12.6\msvc2017_64\include\QtWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtMultimedia -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtANGLE -IE:\Qt\5.12.6\msvc2017_64\include\QtConcurrent -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtNetwork -IE:\Qt\5.12.6\msvc2017_64\include\QtSql -IE:\Qt\5.12.6\msvc2017_64\include\QtXml -IE:\Qt\5.12.6\msvc2017_64\include\QtTextToSpeech -IE:\Qt\5.12.6\msvc2017_64\include\QtSerialPort -IE:\Qt\5.12.6\msvc2017_64\include\QtTest -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6\QtCore -IE:\Qt\5.12.6\msvc2017_64\include\QtCore -Imoc -I/include -IE:\Qt\5.12.6\msvc2017_64\mkspecs\win32-msvc -Foobj\ @C:\Users\ppott\AppData\Local\Temp\QGCTileCacheWorker.obj.15728.12579.jom
C:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QGCTileCacheWorker.cpp(719): error C2220: warning treated as error - no ‘object’ file generated
C:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QGCTileCacheWorker.cpp(719): warning C4819: The file contains a character that cannot be represented in the current code page (936). Save the file in Unicode format to prevent data loss
jom: C:\Users\ppott\Documents\build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Debug\Makefile [obj\QGCTileCacheWorker.obj] Error 2
cl -c -FIstable_headers.h -Yustable_headers.h -Fpobj\QGroundControl_pch.pch -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:throwingNew -Zc:referenceBinding -Zc:_cplusplus -Zi -MDd -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 /W3 /wd4996 /wd4005 /wd4290 /wd4267 /WX -EHsc /Fdobj\QGroundControl.vc.pdb -DUNICODE -D_UNICODE -DWIN32 -D_ENABLE_EXTENDED_ALIGNED_STORAGE -DWIN64 -DQGC_GST_TAISYNC_DISABLED -DQGC_GST_MICROHARD_DISABLED -D__STDC_LIMIT_MACROS -DQGC_ENABLE_MAVLINK_INSPECTOR -DGIT_VERSION="“Development master:5ca19ecc3 2020-03-12 23:24:30 +0000"” -DEIGEN_MPL2_ONLY -D_TTY_NOWARN -DQGC_DISABLE_PAIRING -DQGC_USE_ARDUPILOTMEGA_MESSAGES -DNOMINMAX -DQGC_APPLICATION_NAME="“QGroundControl”" -DQGC_ORG_NAME="“QGroundControl.org”" -DQGC_ORG_DOMAIN="“org.qgroundcontrol”" -DUNITTEST_BUILD -DQT_LOCATION_LIB -DQT_POSITIONINGQUICK_LIB -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_CHARTS_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CONCURRENT_LIB -DQT_POSITIONING_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_TEXTTOSPEECH_LIB -DQT_SERIALPORT_LIB -DQT_TESTLIB_LIB -DQT_CORE_LIB -DQT_TESTCASE_BUILDDIR="“C:/Users/ppott/Documents/build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Debug”" -DQT_QML_DEBUG -IC:\Users\ppott\Documents\qgroundcontrol -I. -IE:\Qt\5.12.6\msvc2017_64\include -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation -IC:\Users\ppott\Documents\qgroundcontrol\libs\msinttypes -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0 -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0\ardupilotmega -IC:\Users\ppott\Documents\qgroundcontrol\libs\eigen -IC:\Users\ppott\Documents\qgroundcontrol\libs\shapelib -IC:\Users\ppott\Documents\qgroundcontrol\libs\sdl2\msvc\include -IC:/Users/ppott/Documents/qgroundcontrol/libs/OpenSSL/Windows/x64/include -IC:\Users\ppott\Documents\qgroundcontrol -Iinclude/ui -IC:\Users\ppott\Documents\qgroundcontrol\src -IC:\Users\ppott\Documents\qgroundcontrol\src\ADSB -IC:\Users\ppott\Documents\qgroundcontrol\src\api -IC:\Users\ppott\Documents\qgroundcontrol\src\AnalyzeView -IC:\Users\ppott\Documents\qgroundcontrol\src\Camera -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightDisplay -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap\Widgets -IC:\Users\ppott\Documents\qgroundcontrol\src\FollowMe -IC:\Users\ppott\Documents\qgroundcontrol\src\Geo -IC:\Users\ppott\Documents\qgroundcontrol\src\GPS -IC:\Users\ppott\Documents\qgroundcontrol\src\Joystick -IC:\Users\ppott\Documents\qgroundcontrol\src\PlanView -IC:\Users\ppott\Documents\qgroundcontrol\src\MissionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\PositionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\QmlControls -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QMLControl -IC:\Users\ppott\Documents\qgroundcontrol\src\Settings -IC:\Users\ppott\Documents\qgroundcontrol\src\Terrain -IC:\Users\ppott\Documents\qgroundcontrol\src\Vehicle -IC:\Users\ppott\Documents\qgroundcontrol\src\ViewWidgets -IC:\Users\ppott\Documents\qgroundcontrol\src\Audio -IC:\Users\ppott\Documents\qgroundcontrol\src\comm -Isrc/input -Isrc/lib/qmapcontrol -IC:\Users\ppott\Documents\qgroundcontrol\src\uas -IC:\Users\ppott\Documents\qgroundcontrol\src\ui -Isrc/ui/linechart -Isrc/ui/map -Isrc/ui/mapdisplay -Isrc/ui/mission -Isrc/ui/px4_configuration -IC:\Users\ppott\Documents\qgroundcontrol\src\ui\toolbar -Isrc/ui/uas -IC:\Users\ppott\Documents\qgroundcontrol\src\qgcunittest -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\Common -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\VehicleSetup -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem\FactControls -IC:\Users\ppott\Documents\qgroundcontrol\src\Airmap\dummy -IC:\Users\ppott\Documents\qgroundcontrol\src\VideoStreaming -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6\QtLocation -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuickWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtOpenGL -IE:\Qt\5.12.6\msvc2017_64\include\QtSvg -IE:\Qt\5.12.6\msvc2017_64\include\QtPrintSupport -IE:\Qt\5.12.6\msvc2017_64\include\QtCharts -IE:\Qt\5.12.6\msvc2017_64\include\QtWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtMultimedia -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtANGLE -IE:\Qt\5.12.6\msvc2017_64\include\QtConcurrent -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtNetwork -IE:\Qt\5.12.6\msvc2017_64\include\QtSql -IE:\Qt\5.12.6\msvc2017_64\include\QtXml -IE:\Qt\5.12.6\msvc2017_64\include\QtTextToSpeech -IE:\Qt\5.12.6\msvc2017_64\include\QtSerialPort -IE:\Qt\5.12.6\msvc2017_64\include\QtTest -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6\QtCore -IE:\Qt\5.12.6\msvc2017_64\include\QtCore -Imoc -I/include -IE:\Qt\5.12.6\msvc2017_64\mkspecs\win32-msvc -Foobj\ @C:\Users\ppott\AppData\Local\Temp\UnitTest.obj.15728.12657.jom
UnitTest.cc
cl -c -FIstable_headers.h -Yustable_headers.h -Fpobj\QGroundControl_pch.pch -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:throwingNew -Zc:referenceBinding -Zc:_cplusplus -Zi -MDd -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 /W3 /wd4996 /wd4005 /wd4290 /wd4267 /WX -EHsc /Fdobj\QGroundControl.vc.pdb -DUNICODE -D_UNICODE -DWIN32 -D_ENABLE_EXTENDED_ALIGNED_STORAGE -DWIN64 -DQGC_GST_TAISYNC_DISABLED -DQGC_GST_MICROHARD_DISABLED -D__STDC_LIMIT_MACROS -DQGC_ENABLE_MAVLINK_INSPECTOR -DGIT_VERSION="“Development master:5ca19ecc3 2020-03-12 23:24:30 +0000"” -DEIGEN_MPL2_ONLY -D_TTY_NOWARN -DQGC_DISABLE_PAIRING -DQGC_USE_ARDUPILOTMEGA_MESSAGES -DNOMINMAX -DQGC_APPLICATION_NAME="“QGroundControl”" -DQGC_ORG_NAME="“QGroundControl.org”" -DQGC_ORG_DOMAIN="“org.qgroundcontrol”" -DUNITTEST_BUILD -DQT_LOCATION_LIB -DQT_POSITIONINGQUICK_LIB -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_CHARTS_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CONCURRENT_LIB -DQT_POSITIONING_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_TEXTTOSPEECH_LIB -DQT_SERIALPORT_LIB -DQT_TESTLIB_LIB -DQT_CORE_LIB -DQT_TESTCASE_BUILDDIR="“C:/Users/ppott/Documents/build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Debug”" -DQT_QML_DEBUG -IC:\Users\ppott\Documents\qgroundcontrol -I. -IE:\Qt\5.12.6\msvc2017_64\include -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation -IC:\Users\ppott\Documents\qgroundcontrol\libs\msinttypes -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0 -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0\ardupilotmega -IC:\Users\ppott\Documents\qgroundcontrol\libs\eigen -IC:\Users\ppott\Documents\qgroundcontrol\libs\shapelib -IC:\Users\ppott\Documents\qgroundcontrol\libs\sdl2\msvc\include -IC:/Users/ppott/Documents/qgroundcontrol/libs/OpenSSL/Windows/x64/include -IC:\Users\ppott\Documents\qgroundcontrol -Iinclude/ui -IC:\Users\ppott\Documents\qgroundcontrol\src -IC:\Users\ppott\Documents\qgroundcontrol\src\ADSB -IC:\Users\ppott\Documents\qgroundcontrol\src\api -IC:\Users\ppott\Documents\qgroundcontrol\src\AnalyzeView -IC:\Users\ppott\Documents\qgroundcontrol\src\Camera -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightDisplay -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap\Widgets -IC:\Users\ppott\Documents\qgroundcontrol\src\FollowMe -IC:\Users\ppott\Documents\qgroundcontrol\src\Geo -IC:\Users\ppott\Documents\qgroundcontrol\src\GPS -IC:\Users\ppott\Documents\qgroundcontrol\src\Joystick -IC:\Users\ppott\Documents\qgroundcontrol\src\PlanView -IC:\Users\ppott\Documents\qgroundcontrol\src\MissionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\PositionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\QmlControls -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QMLControl -IC:\Users\ppott\Documents\qgroundcontrol\src\Settings -IC:\Users\ppott\Documents\qgroundcontrol\src\Terrain -IC:\Users\ppott\Documents\qgroundcontrol\src\Vehicle -IC:\Users\ppott\Documents\qgroundcontrol\src\ViewWidgets -IC:\Users\ppott\Documents\qgroundcontrol\src\Audio -IC:\Users\ppott\Documents\qgroundcontrol\src\comm -Isrc/input -Isrc/lib/qmapcontrol -IC:\Users\ppott\Documents\qgroundcontrol\src\uas -IC:\Users\ppott\Documents\qgroundcontrol\src\ui -Isrc/ui/linechart -Isrc/ui/map -Isrc/ui/mapdisplay -Isrc/ui/mission -Isrc/ui/px4_configuration -IC:\Users\ppott\Documents\qgroundcontrol\src\ui\toolbar -Isrc/ui/uas -IC:\Users\ppott\Documents\qgroundcontrol\src\qgcunittest -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\Common -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\VehicleSetup -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem\FactControls -IC:\Users\ppott\Documents\qgroundcontrol\src\Airmap\dummy -IC:\Users\ppott\Documents\qgroundcontrol\src\VideoStreaming -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6\QtLocation -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuickWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtOpenGL -IE:\Qt\5.12.6\msvc2017_64\include\QtSvg -IE:\Qt\5.12.6\msvc2017_64\include\QtPrintSupport -IE:\Qt\5.12.6\msvc2017_64\include\QtCharts -IE:\Qt\5.12.6\msvc2017_64\include\QtWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtMultimedia -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtANGLE -IE:\Qt\5.12.6\msvc2017_64\include\QtConcurrent -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtNetwork -IE:\Qt\5.12.6\msvc2017_64\include\QtSql -IE:\Qt\5.12.6\msvc2017_64\include\QtXml -IE:\Qt\5.12.6\msvc2017_64\include\QtTextToSpeech -IE:\Qt\5.12.6\msvc2017_64\include\QtSerialPort -IE:\Qt\5.12.6\msvc2017_64\include\QtTest -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6\QtCore -IE:\Qt\5.12.6\msvc2017_64\include\QtCore -Imoc -I/include -IE:\Qt\5.12.6\msvc2017_64\mkspecs\win32-msvc -Foobj\ @C:\Users\ppott\AppData\Local\Temp\UnitTestList.obj.15728.12766.jom
UnitTestList.cc
cl -c -FIstable_headers.h -Yustable_headers.h -Fpobj\QGroundControl_pch.pch -nologo -Zc:wchar_t -FS -Zc:rvalueCast -Zc:inline -Zc:throwingNew -Zc:referenceBinding -Zc:_cplusplus -Zi -MDd -W3 -w34100 -w34189 -w44996 -w44456 -w44457 -w44458 -wd4577 -wd4467 /W3 /wd4996 /wd4005 /wd4290 /wd4267 /WX -EHsc /Fdobj\QGroundControl.vc.pdb -DUNICODE -D_UNICODE -DWIN32 -D_ENABLE_EXTENDED_ALIGNED_STORAGE -DWIN64 -DQGC_GST_TAISYNC_DISABLED -DQGC_GST_MICROHARD_DISABLED -D__STDC_LIMIT_MACROS -DQGC_ENABLE_MAVLINK_INSPECTOR -DGIT_VERSION="“Development master:5ca19ecc3 2020-03-12 23:24:30 +0000"” -DEIGEN_MPL2_ONLY -D_TTY_NOWARN -DQGC_DISABLE_PAIRING -DQGC_USE_ARDUPILOTMEGA_MESSAGES -DNOMINMAX -DQGC_APPLICATION_NAME="“QGroundControl”" -DQGC_ORG_NAME="“QGroundControl.org”" -DQGC_ORG_DOMAIN="“org.qgroundcontrol”" -DUNITTEST_BUILD -DQT_LOCATION_LIB -DQT_POSITIONINGQUICK_LIB -DQT_QUICKWIDGETS_LIB -DQT_QUICK_LIB -DQT_OPENGL_LIB -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_CHARTS_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_CONCURRENT_LIB -DQT_POSITIONING_LIB -DQT_QML_LIB -DQT_NETWORK_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_TEXTTOSPEECH_LIB -DQT_SERIALPORT_LIB -DQT_TESTLIB_LIB -DQT_CORE_LIB -DQT_TESTCASE_BUILDDIR="“C:/Users/ppott/Documents/build-qgroundcontrol-Desktop_Qt_5_12_6_MSVC2017_64bit-Debug”" -DQT_QML_DEBUG -IC:\Users\ppott\Documents\qgroundcontrol -I. -IE:\Qt\5.12.6\msvc2017_64\include -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation -IC:\Users\ppott\Documents\qgroundcontrol\libs\msinttypes -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0 -IC:\Users\ppott\Documents\qgroundcontrol\libs\mavlink\include\mavlink\v2.0\ardupilotmega -IC:\Users\ppott\Documents\qgroundcontrol\libs\eigen -IC:\Users\ppott\Documents\qgroundcontrol\libs\shapelib -IC:\Users\ppott\Documents\qgroundcontrol\libs\sdl2\msvc\include -IC:/Users/ppott/Documents/qgroundcontrol/libs/OpenSSL/Windows/x64/include -IC:\Users\ppott\Documents\qgroundcontrol -Iinclude/ui -IC:\Users\ppott\Documents\qgroundcontrol\src -IC:\Users\ppott\Documents\qgroundcontrol\src\ADSB -IC:\Users\ppott\Documents\qgroundcontrol\src\api -IC:\Users\ppott\Documents\qgroundcontrol\src\AnalyzeView -IC:\Users\ppott\Documents\qgroundcontrol\src\Camera -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightDisplay -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap -IC:\Users\ppott\Documents\qgroundcontrol\src\FlightMap\Widgets -IC:\Users\ppott\Documents\qgroundcontrol\src\FollowMe -IC:\Users\ppott\Documents\qgroundcontrol\src\Geo -IC:\Users\ppott\Documents\qgroundcontrol\src\GPS -IC:\Users\ppott\Documents\qgroundcontrol\src\Joystick -IC:\Users\ppott\Documents\qgroundcontrol\src\PlanView -IC:\Users\ppott\Documents\qgroundcontrol\src\MissionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\PositionManager -IC:\Users\ppott\Documents\qgroundcontrol\src\QmlControls -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\QtLocationPlugin\QMLControl -IC:\Users\ppott\Documents\qgroundcontrol\src\Settings -IC:\Users\ppott\Documents\qgroundcontrol\src\Terrain -IC:\Users\ppott\Documents\qgroundcontrol\src\Vehicle -IC:\Users\ppott\Documents\qgroundcontrol\src\ViewWidgets -IC:\Users\ppott\Documents\qgroundcontrol\src\Audio -IC:\Users\ppott\Documents\qgroundcontrol\src\comm -Isrc/input -Isrc/lib/qmapcontrol -IC:\Users\ppott\Documents\qgroundcontrol\src\uas -IC:\Users\ppott\Documents\qgroundcontrol\src\ui -Isrc/ui/linechart -Isrc/ui/map -Isrc/ui/mapdisplay -Isrc/ui/mission -Isrc/ui/px4_configuration -IC:\Users\ppott\Documents\qgroundcontrol\src\ui\toolbar -Isrc/ui/uas -IC:\Users\ppott\Documents\qgroundcontrol\src\qgcunittest -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\Common -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin -IC:\Users\ppott\Documents\qgroundcontrol\src\VehicleSetup -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\APM -IC:\Users\ppott\Documents\qgroundcontrol\src\AutoPilotPlugins\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FirmwarePlugin\PX4 -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem -IC:\Users\ppott\Documents\qgroundcontrol\src\FactSystem\FactControls -IC:\Users\ppott\Documents\qgroundcontrol\src\Airmap\dummy -IC:\Users\ppott\Documents\qgroundcontrol\src\VideoStreaming -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtLocation\5.12.6\QtLocation -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick\5.12.6\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioningQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuickWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick\5.12.6\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtQuick -IE:\Qt\5.12.6\msvc2017_64\include\QtOpenGL -IE:\Qt\5.12.6\msvc2017_64\include\QtSvg -IE:\Qt\5.12.6\msvc2017_64\include\QtPrintSupport -IE:\Qt\5.12.6\msvc2017_64\include\QtCharts -IE:\Qt\5.12.6\msvc2017_64\include\QtWidgets -IE:\Qt\5.12.6\msvc2017_64\include\QtMultimedia -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtGui\5.12.6\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtGui -IE:\Qt\5.12.6\msvc2017_64\include\QtANGLE -IE:\Qt\5.12.6\msvc2017_64\include\QtConcurrent -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning\5.12.6\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtPositioning -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtQml\5.12.6\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtQml -IE:\Qt\5.12.6\msvc2017_64\include\QtNetwork -IE:\Qt\5.12.6\msvc2017_64\include\QtSql -IE:\Qt\5.12.6\msvc2017_64\include\QtXml -IE:\Qt\5.12.6\msvc2017_64\include\QtTextToSpeech -IE:\Qt\5.12.6\msvc2017_64\include\QtSerialPort -IE:\Qt\5.12.6\msvc2017_64\include\QtTest -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6 -IE:\Qt\5.12.6\msvc2017_64\include\QtCore\5.12.6\QtCore -IE:\Qt\5.12.6\msvc2017_64\include\QtCore -Imoc -I/include -IE:\Qt\5.12.6\msvc2017_64\mkspecs\win32-msvc -Foobj\ @C:\Users\ppott\AppData\Local\Temp\SendMavCommandTest.obj.15728.12860.jom
SendMavCommandTest.cc
GPSRTKFactGroup.cc
Generating Code…
21:29:00: The process “E:\Qt\Tools\QtCreator\bin\jom.exe” exited with code 2.
Error while building/deploying project qgroundcontrol (kit: Desktop Qt 5.12.6 MSVC2017 64bit)
When executing step “Make”
21:29:00: Elapsed time: 00:22.
