hello how are you all, my problem is that accidentally pull the micro usb cable and the component inside that makes the connection is desoldered and broke, there will be some other way to load the firmware to the plate without the micro usb cable or some solution how can I repair it and if it is reliable to weld it again.
Thank you all
there is another way of uploading firmware from command line through UART5(the system debug port).
Depends on the damage, If USB pads are all pealed off then quite less possible to weld on again.
