ArUco marker detection not working with ROS2 and PX4 SITL
I’m working on a project where I need to detect ArUco markers using ROS2 and PX4 SITL. I’ve implemented a Python script that subscribes to the camera topic and uses OpenCV to detect ArUco markers in the image stream. However, despite running the script, the markers are not being detected, and there are no errors displayed. The image window opens, but no markers are drawn
import rclpy  # Python library for ROS 2
from rclpy.node  import Node  # Handles the creation of nodes
from rclpy.qos  import qos_profile_sensor_data  # Uses Best Effort reliability for camera
from cv_bridge  import CvBridge  # Package to convert between ROS and OpenCV Images
from geometry_msgs.msg  import TransformStamped  # Handles TransformStamped message
from sensor_msgs.msg  import Image  # Image is the message type
from std_msgs.msg  import Bool # Handles boolean messages
from std_msgs.msg  import Int32  # Handles int 32 type message
# Import Python libraries
import cv2  # OpenCV library
import numpy as np  # Import Numpy library
# The different ArUco dictionaries built into the OpenCV library.
ARUCO_DICT  = {
   "DICT_4X4_50" : cv2.aruco.DICT_4X4_50,
   "DICT_4X4_100" : cv2.aruco.DICT_4X4_100,
   "DICT_4X4_250" : cv2.aruco.DICT_4X4_250,
   "DICT_4X4_1000" : cv2.aruco.DICT_4X4_1000,
   "DICT_5X5_50" : cv2.aruco.DICT_5X5_50,
   "DICT_5X5_100" : cv2.aruco.DICT_5X5_100,
   "DICT_5X5_250" : cv2.aruco.DICT_5X5_250,
   "DICT_5X5_1000" : cv2.aruco.DICT_5X5_1000,
   "DICT_6X6_50" : cv2.aruco.DICT_6X6_50,
   "DICT_6X6_100" : cv2.aruco.DICT_6X6_100,
   "DICT_6X6_250" : cv2.aruco.DICT_6X6_250,
   "DICT_6X6_1000" : cv2.aruco.DICT_6X6_1000,
   "DICT_7X7_50" : cv2.aruco.DICT_7X7_50,
   "DICT_7X7_100" : cv2.aruco.DICT_7X7_100,
   "DICT_7X7_250" : cv2.aruco.DICT_7X7_250,
   "DICT_7X7_1000" : cv2.aruco.DICT_7X7_1000,
   "DICT_ARUCO_ORIGINAL" : cv2.aruco.DICT_ARUCO_ORIGINAL
class ArucoNode(Node):
   Create an ArucoNode class, which is a subclass of the Node class.
   def __init__( self ):
     Class constructor to set up the node
     # Initiate the Node class's constructor and give it a name
     super ().__init__( 'aruco_node' )
     # Declare parameters
     self .declare_parameter( "aruco_dictionary_name" ,  "DICT_ARUCO_ORIGINAL" )
     self .declare_parameter( "aruco_marker_side_length" ,  0.05 )
     self .declare_parameter( "camera_calibration_parameters_filename" ,  "/home/focalfossa/dev_ws/src/two_wheeled_robot/scripts/calibration_chessboard.yaml" )
     self .declare_parameter( "image_topic" ,  "/depth_camera/image_raw" )
     self .declare_parameter( "aruco_marker_name" ,  "aruco_marker" )
     # Read parameters
     aruco_dictionary_name  = self .get_parameter( "aruco_dictionary_name" ).get_parameter_value().string_value
     self .aruco_marker_side_length  = self .get_parameter( "aruco_marker_side_length" ).get_parameter_value().double_value
     self .camera_calibration_parameters_filename  = self .get_parameter(
       "camera_calibration_parameters_filename" ).get_parameter_value().string_value
     image_topic  = self .get_parameter( "image_topic" ).get_parameter_value().string_value
     self .aruco_marker_name  = self .get_parameter( "aruco_marker_name" ).get_parameter_value().string_value
     # Check that we have a valid ArUco marker
     if ARUCO_DICT.get(aruco_dictionary_name,  None )  is None :
       self .get_logger().info( "[INFO] ArUCo tag of '{}' is not supported" . format (
         args[ "type" ]))
     # Load the camera parameters from the saved file
     cv_file  = cv2.FileStorage(
       self .camera_calibration_parameters_filename, cv2.FILE_STORAGE_READ)
     self .mtx  = cv_file.getNode( 'K' ).mat()
     self .dst  = cv_file.getNode( 'D' ).mat()
     cv_file.release()
     # Load the ArUco dictionary
     self .get_logger().info( "[INFO] detecting '{}' markers..." . format (
       aruco_dictionary_name))
     self .this_aruco_dictionary  = cv2.aruco.Dictionary_get(ARUCO_DICT[aruco_dictionary_name])
     self .this_aruco_parameters  = cv2.aruco.DetectorParameters_create()
     # Create the subscriber. This subscriber will receive an Image
     # from the image_topic.
     self .subscription  = self .create_subscription(
       Image,
       image_topic,
       self .listener_callback,
       qos_profile = qos_profile_sensor_data)
     self .subscription  # prevent unused variable warning
     # Create the publishers
     # Publishes if an ArUco marker was detected
     self .publisher_aruco_marker_detected  = self .create_publisher( Bool ,  'aruco_marker_detected' ,  10 )
     # Publishes x-centroid offset with respect to the camera image
     self .publisher_offset_aruco_marker  = self .create_publisher(Int32,  'aruco_marker_offset' ,  10 )
     self .offset_aruco_marker  = 0
     # Used to convert between ROS and OpenCV images
     self .bridge  = CvBridge()
   def listener_callback( self , data):
     Callback function.
     # Convert ROS Image message to OpenCV image
     current_frame  = self .bridge.imgmsg_to_cv2(data)
     # Detect ArUco markers in the video frame
     (corners, marker_ids, rejected)  = cv2.aruco.detectMarkers(
       current_frame,  self .this_aruco_dictionary, parameters = self .this_aruco_parameters,
       cameraMatrix = self .mtx, distCoeff = self .dst)
     # ArUco detected (True or False)
     aruco_detected_flag  = Bool ()
     aruco_detected_flag.data  = False
     # ArUco center offset
     aruco_center_offset_msg  = Int32()
     aruco_center_offset_msg.data  = self .offset_aruco_marker
     image_width  = current_frame.shape[ 1 ]
     # Check that at least one ArUco marker was detected
     if marker_ids  is not None :
       # ArUco marker has been detected
       aruco_detected_flag.data  = True
       # Draw a square around detected markers in the video frame
       cv2.aruco.drawDetectedMarkers(current_frame, corners, marker_ids)
       # Update the ArUco marker offset
       M  = cv2.moments(corners[ 0 ][ 0 ])
       cX  = int (M[ "m10" ]  / M[ "m00" ])
       cY  = int (M[ "m01" ]  / M[ "m00" ])
       self .offset_aruco_marker  = cX  - int (image_width / 2 )
       cv2.putText(current_frame,  "Center Offset: " + str ( self .offset_aruco_marker), (cX  - 40 , cY  - 40 ),
         cv2.FONT_HERSHEY_COMPLEX,  0.7 , ( 0 ,  255 ,  0 ),  2 )
     # Publish if ArUco marker has been detected or not
     self .publisher_aruco_marker_detected.publish(aruco_detected_flag)
     # Publish the center offset of the ArUco marker
     self .publisher_offset_aruco_marker.publish(aruco_center_offset_msg)
     # Display image for testing
     cv2.imshow( "camera" , current_frame)
     cv2.waitKey( 1 )
def main(args = None ):
   # Initialize the rclpy library
   rclpy.init(args = args)
   # Create the node
   aruco_node  = ArucoNode()
   # Spin the node so the callback function is called.
   rclpy.spin(aruco_node)
   # Destroy the node explicitly
   # (optional - otherwise it will be done automatically
   # when the garbage collector destroys the node object)
   aruco_node.destroy_node()
   # Shutdown the ROS client library for Python
   rclpy.shutdown()
if __name__  = = '__main__' :
   main()
Did you solve the problem?
