Anyone tried using fiber optic video transmission on an FPV drone?
I’ve been looking into fiber optic links instead of traditional wireless video transmission. I’m curious how difficult they are to set up and whether they work reliably on a custom FPV build.
Welcome to the community.
One important distinction is whether you are considering fiber optics for video transmission only or for both video and vehicle-control communications.
For a moving aircraft, the main concerns are not limited to transmission quality. Cable management, mechanical loads, potential snagging and safe behavior following a link failure also need consideration.
Are you exploring this for a tethered research platform or a free-flying FPV aircraft?
That distinction would help clarify which reliability and safety considerations are most relevant.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
The tethered versus free-flying distinction is the key one. Fiber is not really a wireless replacement; on a moving aircraft it means a physical link, so you need to plan for a spool/payout, strain relief at the airframe, snagging risk, and a failsafe that behaves sensibly when the fiber breaks. For video-only, you also still need power and control separately unless you multiplex them over the same fiber. That makes a tethered research platform much more practical than ordinary free-flying FPV.
