High bandwidth alternatives to wifi?
In both ammature robotics and commercial UAV’s I’ve seen WiFi used as the wireless control link medium. The vehicle and ground station will act as a wifi AP or STA, either respectively or vice versa, to create a LAN network. In the pixhawk realm that means mavlink over tcp/udp and encryption is all handled within the wifi transport itself.
This system works and scales well provided you allocate enough budget for a good LAN setup like nice POE switches and multiple AP’s.
What i want to know is if there are other proven links besides wifi that can do this. My criteria are as follows:
High bandwidth - Be able to upload large missions quickly.
Multiple Drones/Systems - Swarms of up to hundreds of drones connected to the GCS at once.
Decent range - a few hundred feet at least.
Encryption - yes please.
Let’s look at why typical telemetry links like SiK radios/RFD900/ExpressLRS Airport won’t do:
They aren’t high bandwidth. Most of these telem links prioritize maximum range and deliver bandwidths at a few KB at best. 5ghz Wifi is much faster.
They only work in pairs. For every drone theres a transciever on the ground too. 50 drones in the air? 50 telemetry transcievers on the GCS. Frequency interference becomes a problem at this scale too. Wifi can reliably handle hundreds of clients without interference and transmit to all of them simultaneously.
My question is with these goals in mind is there a wireless transciever link system besides wifi common in robotics that can fulfill these criteria or is wifi going to remain the best system with these large scale applications? This is for a low cost drone show swarm.
Hi, I am not sure if you are still looking for a solution, but thought answering this post could be a good opportunity to contribute to the overall understanding of RFD900X capabilities.
Full, disclosure, I work at RFDesign.
The vanilla RFD900x SiK firmware would most certainly not allow you to achieve the application you described, but we have successufuly achieved similar goals with Multipoint in the past!
More recently, we have released a new Firmware called V4 - which is still in Beta - that could help you achieve your network goals given that it unlocks two new data rates (430 Kbps and 1 Mbps) and some interesting network topologies.
Please get in touch with support to discuss your specific needs, if you still need help.
