Does anyone have a offboard control example for a fixed-wing drone? All I can really find is this Offboard Mode | PX4 User Guide but all those messages (id 82, 84, 87) are unlisted in VehicleCommand.msg. Is it possible to send raw mavlink messages via ROS2?
@Jan-Hendrik_Ewers Offboard control does not work with VehicleCommand or MAV_CMD_ mavlink messages, therefore I am not sure what you are looking for.
If you send mavlink setpoints, they will work with fixedwing as documented in the userguide.
@Jaeyoung-Lim maybe offboard control is the wrong term. I’m just looking for any examples of FW being controlled via ROS2.
So the setpoints like “AttitudeSetpoint_PubSubTopic”, “PositionSetpoint_PubSubTopic”, etc.?
Could you point me towards that section of the userguide? I must have missed it.
@Jaeyoung-Lim was right, using the setpoints worked well. I am currently testing the VehicleAttitudeSetpoint_PubSubTopic with roll_body = math.sin(time.time()/4)*0.05 and it’s giving very nice responses.
Should I upload the code as an example somewhere?
@Jan-Hendrik_Ewers Great! Adding it to the user guide would be definitely cool
GitHub - PX4/PX4-user_guide: PX4 User Guide
Hi @Jaeyoung-Lim, upon further testing it seems like I can control the FW plane using the /VehicleAttitudeSetpoint_PubSubTopic but not via /VehicleLocalPositionSetpoint_PubSubTopic.
From the px4 architecture it looks like these two feed into different controllers
Is there a block within fw_pos_control_l1?
I’m seeing the values that i’m sending within PXH but the SITL is not responding to this command.
pxh> listener vehicle_local_position_setpoint
TOPIC: vehicle_local_position_setpoint
vehicle_local_position_setpoint_s
timestamp: 205431999 (0.128001 seconds ago)
x: 0.0000
y: 0.0000
z: 0.0000
yaw: -3.1400
yawspeed: 0.0000
vx: 0.0000
vy: 0.0000
vz: 0.0000
acceleration: [0.0000, 0.0000, 0.0000]
jerk: [0.0000, 0.0000, 0.0000]
thrust: [0.0000, 0.0000, 0.0000]
Hi,have you found the way to control the fixed wing via ROS2? This problem make me confused.
