How to make QGControl connect to gazebo simulation instance in another host in same LAN?
Hello,I have gazebo simu run in a another host:192.168.10.11 by this scripts:
#!/bin/bash
px4_dir=$(pwd)
source $px4_dir/Tools/setup_gazebo.bash $px4_dir $px4_dir/build/posix_sitl_default
#source devel/setup.bash
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$px4_dir
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$px4_dir/Tools/sitl_gazebo
roslaunch px4 posix_sitl.launch
and the console output like this:
GAZEBO_PLUGIN_PATH :/home/x-man/Firmware/build/posix_sitl_default/build_gazebo
GAZEBO_MODEL_PATH :/home/x-man/Firmware/Tools/sitl_gazebo/models
LD_LIBRARY_PATH /home/x-man/catkin_ws/devel/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/x86_64-linux-gnu:/usr/local/lib:/home/x-man/Firmware/build/posix_sitl_default/build_gazebo
... logging to /home/x-man/.ros/log/b80d9922-4396-11e9-a728-0800273e9aa6/roslaunch-x-test-6238.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://x-test:43745/
SUMMARY
PARAMETERS
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
 * /use_sim_time: True
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    sitl (px4/px4)
    vehicle_spawn_x_test_6238_688026835630494011 (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [6294]
ROS_MASTER_URI=http://localhost:11311
process[vehicle_spawn_x_test_6238_688026835630494011-5]: started with pid [6322]
INFO  [px4] Creating symlink /home/x-man/Firmware/ROMFS/px4fmu_common -> /home/x-man/.ros/etc
0 WARNING: setRealtimeSched failed (not run as root?)
______  __   __    ___
| ___ \ \ \ / /   /   |
| |_/ /  \ V /   / /| |
|  __/   /   \  / /_| |
| |     / /^\ \ \___  |
\_|     \/   \/     |_/
px4 starting.
INFO  [px4] Calling startup script: /bin/sh etc/init.d-posix/rcS 0
  SYS_AUTOSTART: curr: 0 -> new: 10016
  BAT_N_CELLS: curr: 0 -> new: 3
  PWM_MAX: curr: 2000 -> new: 1950
  PWM_MIN: curr: 1000 -> new: 1075
INFO  [dataman] Unknown restart, data manager file './dataman' size is 11798680 bytes
INFO  [simulator] Waiting for simulator to connect on TCP port 4560
SpawnModel script started
[ INFO] [1552265046.945923218]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1552265049.043329814, 0.112000000]: Physics dynamic reconfigure ready.
[vehicle_spawn_x_test_6238_688026835630494011-5] process has finished cleanly
log file: /home/x-man/.ros/log/b80d9922-4396-11e9-a728-0800273e9aa6/vehicle_spawn_x_test_6238_688026835630494011-5*.log
In QGroundControl->settings->Comm Links,I have tried to create TCP links to this host(192.168.10.11) by different port:
43745
11311
4560
but all failed,so question is:
How to use gqcontrol to connect to gazebo simulation instance in another host in same LAN?
You need to tell PX4 to send UDP to the other computer.
There are two ways:
  1. Broadcast in your local subnet. The first QGC that sees a heartbeat will connect. If you have more than one computer with QGC open, you have a race.
  2. Add the IP of the computer with e.g. -t 192.168.x.y here:
    https://github.com/PX4/Firmware/blob/6672284871d4cd4163e99d68e75831d0495f58c8/ROMFS/px4fmu_common/init.d-posix/rcS#L226
It connected,thanks very much @JulianOes
