I am trying to control the yaw for the iris_opt_flow model in px4 sitl using mavros_msgs PositionTarget and publishing it onto “/mavros/setpoint_raw/local” topic.
I have the following bitmask for the type mask field for the yaw setpoint
“0b0000010111111111”. The rate that I am publishing it for is 10 hz.
All the commands are sent when offboard mode is enabled.
I have checked that the following.
- Bimask for position setpoint (0b0000111111111000) works even at 1Hz
- Bimask for velocity setpoint (0b0000111111000111) works even at 1Hz
- Bimask for force setpoint (0b000011000111111) works even at 1Hz
My question is the following
- Is the yaw setpoiont enabled for the px4 sitl environment with gazebo9?
- If it it is supported then could you guys help point out any other solutions ?
Thanks,
ANiket
