Did you successfully run QGC on the desktop?
error: linker command failed with exit code 1 (use -v to see invocation)
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
i am getting this error please if any have answer just ping me.
i am using QGCS version 6.8.2
Are you trying to build from Master or Stable?
I am using master version
@bylla_anusha hey i am successfully run qgcs on the desktop but faild to run on the Android
QGC doesn’t have a v6 release, so you should check again what you are trying to do.
Also I’m closing this issue since its original intention has been long closed at this point. Please create a new post if your problems persist.
