Why the esc_status frequency is much lower than Dshot frequency when bidirectional dshot is enabled
Dear all,
I am curious about what determines the frequency of the bidirectional DShot feedback (ESC status). When I attempt direct motor control via ROS2 at a frequency of 500 Hz, I observe the following in the working queue, indicating that the DShot is running at 500 Hz:
Work Queue: 10 threads                          RATE        INTERVAL
|__ 1) wq:rate_ctrl
|   |__ 1) control_allocator                 20.0 Hz        49996 us
|   |__ 2) dshot                            500.0 Hz         2000 us
|   |__ 3) mc_rate_control                 2003.1 Hz          499 us
|   \__ 4) vehicle_angular_velocity        2003.1 Hz          499 us
|__ 2) wq:SPI1
I have increased the DDS frequency under the suggestion mentioned in this question
However, the frequency of esc_status is only ~45 Hz by ros2 topic hz /fmu/out/esc_status.
average rate: 42.159
	min: 0.015s max: 0.051s std dev: 0.01121s window: 43
average rate: 42.865
	min: 0.014s max: 0.083s std dev: 0.01229s window: 87
average rate: 42.028
	min: 0.014s max: 0.083s std dev: 0.01260s window: 128
average rate: 44.132
	min: 0.009s max: 0.083s std dev: 0.01174s window: 179
average rate: 45.366
	min: 0.009s max: 0.083s std dev: 0.01109s window: 230
average rate: 45.637
	min: 0.009s max: 0.083s std dev: 0.01079s window: 278
average rate: 45.315
	min: 0.009s max: 0.083s std dev: 0.01099s window: 323
I also noticed that when I decrease the Dshot frequency, the frequency of esc_status decreases as well. Is there any correlation between the two?
Additionally, I’m wondering how I can increase the feedback frequency of the esc_status.
Thank you all!
@Benja @farhang sorry to bother you, but I would really appreciate it if you or someone you know is familiar with the Dshot component. :face_holding_back_tears:
Bidirectional DShot is available for fmuv6xrt fmuv6xrt implement bidirectional dshot by PetervdPerk-NXP · Pull Request #22583 · PX4/PX4-Autopilot · GitHub
Are you using that board?
General Bidirectional DShot is still an open PR: [Sponsored by ARK] Bidirectional DShot by dakejahl · Pull Request #23863 · PX4/PX4-Autopilot · GitHub
Are you testing that branch or are you using the standard DShot telemetry over serial port? Parameter Reference | PX4 Guide (main)
Yes, I am testing it with a serial port
and I am testing with the main branch, using the hkust_nxt-dual_default board.
Based on my understanding, the bidirectional DShot protocol allows for obtaining ERPM feedback at a frequency matching the DShot motor control frequency (i.e., over 2000 Hz), without requiring telemetry over the serial port. However, as I’m reviewing the firmware, I’m uncertain if this functionality is supported in PX4. Part of my knowledge comes from the Betaflight documentation, as outlined below:
I am looking to implement a closed-loop motor speed control system based on ERPM feedback, and I hope the feedback frequency can match the control frequency. Could I kindly ask if, based on your knowledge, this is feasible? @Benja
I found that I was unable to enable bidirectional DShot, but I did receive ERPM data via telemetry. My hardware is this, and I’m wondering, in addition to enabling DSHOT_BIDIR_EN, what other configurations are necessary to fully enable bidirectional DShot?
I’ve been looking at DShot for the past week+. I found this thread when searching for the dshot loop rate. I am running a custom fork of PX4, based on 1.15 but I pulled in two recent PRs for bi-directional DShot support
These were merged into PX4 main, so if you are using that you should be all set. They added a new parameter, DSHOT_BIDIR_EN, set that to 1 and try it out.
Typing “work_queue status” I see that my dshot loop is 800 hz, and that matches up with my o-scope readings of ~1.2 ms between dshot command packets.
Now I am getting the dshot response packets with eRPM data. Our drones use AM32 ESC boards, so I kinda have to keep an eye on what is in PX4 and what the AM32 source code expects. For instance, esc_info in PX4 only sends command 6 once, but AM32 expects 6 repetitions of that command before it replies.
Oh also, you mention that you are using the telemetry for eRPM data, but I read that using serial telemetry responses is far too slow to be used in active RPM-filtering, it’s more just useful for logging/review. Found that info here DSHOT - the missing Handbook | Brushless Whoop
I’m developing an ESC to support bidirectional D-SHOT, but I’m unsure how to test the return signal. Could you help clarify this for me? I enabled DSHOT_BIDIR_EN in the parameters and tested the motor in the Actuators interface, but the logic analyzer shows the signal levels aren’t inverting.
What version of PX4? I believe the DSHOT_BIRID_EN is only in 1.16 and above. But as I recall it should be in effect when you set that param to 1 and reboot.
Oh, thanks a lot. My PX4 version is under 1.16. I will try it on later version.
