VTOL Manual Motor Shutoff
I am currently working on a Gazebo Sim standard VTOL, trying to look into disabling the fixed wing motor mid-flight. The idea behind this is to compare the total power consumption between a constant altitude flight, versus letting the drone glide to a certain altitude, and then re-enabling the motors to regain altitude as needed.
I am looking for advice on how I can most easily create this motor shutoff. I have tried setting the minimum thrust and speed values to zero and attempting to make a mission where these values are set to zero. However, this approach never seemed to work, and any mission configurations I tried did not give the shutdown I was looking for.
I am currently building a simple uORB topic with a boolean parameter, which is set by a MAVLink command to control this interaction. This uORB topic would then control the vehicle thrust setpoint to 0 or its regular value. While this approach works conceptually, it feels somewhat more complex than necessary and might cause more issues down the line.
You could trigger motor failure and then disable failsafes
