I have programmed a custom quadcopter autopilot using the px4_simple_app module.
The problem I have is when my program exits, it stops controlling the motors (as expected), but then the motors automatically go to some random throttle value, like 50%.
I need to remove this problem, because I will be flight testing and I do not want the motors to automatically engage and cause the vehicle to fly out of control when the program ends.
The reason I deactivated “mc_att_control” was because the program would attempt to send PWM signals to the motors while my program was running, and was causing twitching.
I do not affect the basic start up programs, I only deactivate “mc_att_control” and activate my program using the “extras.txt” file. Do I need to deactivate another program that might automatically send PWM signals?
Or is there another way to solve the problem?
Should I make the program in to a daemon so that it runs automatically in the background?
Or should I create my custom start up using RC.txt? and only activate the essentials for attitude data.
Thank you.
