Using external barometer with PX4 version 1.11
Hi all! I am trying to use an external barometer to measure the air pressure and temperature, but am having trouble logging the data to the .ulog file. When I look at the ulog, I can see recorded data for the two internal barometers of the cube orange and the recorded data from my air velocity sensor connected on the same I2C bus as the external barometer, but not the data for the external barometer itself.
I am using a cube orange flight controller with px4 1.11 flashed to it. The off-board software I use only works with 1.11, so I cannot upgrade it. I have tried three different barometers, the GY-63, the CJMCU-25, and the CJMCU-06 connected through an I2C bus into the I2C port of the cube orange.
I can tell that the cube orange is receiving data from the barometer, as I can see the pressure altitude EKF change by about 50 ft when the barometer is install and uninstalled. I have looked through the documentation to see if there is a specific parameter i need to change for it to log data like newer versions of px4, but cannot find what I need to change for 1.11.
Thanks in advance, any help would be appreciated!
