I would like to add my airframe to the flying wing to QGC so it appears in the drop down when selecting flying wings. I have seen the written instructions but do not have the technical skill to get it into the QGC database. Is there another way of loading it?
Where is your configuration file located? Are you loading it off your SD card or have you compiled the configuration in the PX4 firmware? If it is compiled in the firmware, QGC will automatically read it and display it as an optional configuration under airframe.
My config file is on the SD card. I want to get the frame in the QGC actual data base so it shows up when someone downloads it. The frame is not supported on there yet.
@Justin_Cooper Can you send me your config via email? I can add it for you.
