Trying to install the software needed for development onto a device with Linux Mint. Everything looks good, until the last step where python is installed.
when I input this code, I get a error saying there is no “gcc-arm-embedded” package to be found. Is there a way to install this package manually? Or did I mess up something in the installation?
The instruction very clearly state that we’re only supporting Ubuntu officially. If you use something else you should know how to get software packages on your system.
Figured it out. I inputted sudo add-apt-repository ppa:team-gcc-arm-embedded/ppa and did not confirm I wanted it installed. Software installed smoothly this time, thanks for the pointer.
Did you manage to solve that problem? I am having the exact same problem. My gcc version isn’t changing despite running that script. I get:
E: Unable to locate package gdb-arm-none-eabi
E: Unable to locate package gcc-arm-embedded
Installing GCC to: /home/fahim/gcc-arm-none-eabi-7-2017-q4-major
GCC already installed.
RESTART YOUR COMPUTER to complete installation of PX4 development toolchain
It seems that running the installation script doesn’t update the arm-gcc to the appropriate version
